R50/53 Is This True Or False
Old Nov 5, 2006 | 07:45 PM
SMC's Avatar
SMC
--- Post 1 ---
I experience this musty smell every morning upon starting of air condition. Send it to the dealer and they have place a odour machine just below the glove box compartment and run the engine at a slightly higher rpm with heater at full blast for 2 hours. Collected the car and drove off and within the next day the smell occurs again and they decided to change out the filter.
--- Post 2 ---
Our dealer told me this morning that all mini's does suffered musty smell coming out from the air condition during initial starting , after they have failed twice to rectified the problem
The first time the remedy was by placing a odour machine just below the glove compartment . Raised the rpm slightly and full blasted the heater for 2 hours but that did not stop the odour smell.
Send in the second time and they have conducted the same old stupid experiment and was a failure. Now the worst is that not only musty smell I get and also after burning smell coming out from the blower.
I am just wondering are they fit to be a mini dealer :impatient Pls advsie and thanking you guys in advance.
Last edited by Edge; Nov 5, 2006 at 08:53 PM. Reason: Merged posts - duplicate topic
Old Nov 5, 2006 | 07:49 PM
ToBFree's Avatar
ToBFree
Check out this link: https://www.northamericanmotoring.co...ad.php?t=79624
I've never heard of an odor machine. Did it have a big nose on it or something?
Old Nov 5, 2006 | 07:58 PM
rsimpson's Avatar
rsimpson
OMG, and odor machine had me rolling... haven't heard of this in a MINI other than reading it in the other thread... could be a few things though, one thing that comes to mind happened to a friend of mine. Basically it boiled down to the carpet getting wet and molding under the dash section that just happened to be in the same area as the vent that pulls in air for re-circulation. His whole car would smell when he turned the AC on MAX.. once he replaced the carpet, it fixed his issue...
Do keep up posted on the fix, I'm sure it will come around again...
Old Nov 5, 2006 | 07:59 PM
ScuderiaMini's Avatar
ScuderiaMini
Uhmmmm, i dont remember that happening to me....
Old Nov 5, 2006 | 08:03 PM
gokartride's Avatar
gokartride
Did this fix it? Every AC odor I've heard of was connected to the filter. Normally, it's dirty socks smell though.
Old Nov 5, 2006 | 08:09 PM
eVal's Avatar
eVal
Do you run the AC on recirculate often? I've heard of that being the cause of AC stinkiness and I run it mostly with outside air as a result (and so far so good).
Old Nov 5, 2006 | 08:10 PM
tsprayfhs's Avatar
tsprayfhs
We have an '02 with over 86,000 miles on the clock, and we have NEVER had a problem with oders. Now I'm not saying it won't happen ... you know after it is broken in. Who knows. The only oder I can detect now is that of rotting service.
Motor on
Old Nov 5, 2006 | 08:22 PM
T2Nav's Avatar
T2Nav
2006 MCS smells like nothing during starting and normal ops. When I start the A/C I sometimes get a pleasant rainy smell for a few seconds then nothing. To keep my system as dry and cootie-free as possible, I never run it on recirculate. Good luck with everything, hope they find the problem.
Old Nov 5, 2006 | 08:23 PM
ma78's Avatar
ma78
Coordinator :: Super Secret Orange County MINI Cooper Club
B.S.
Call MOA.
Old Nov 5, 2006 | 08:24 PM
Motor On's Avatar
Motor On
Only time I smell anything is when I drive past a skunk and I'm not on re-circulate. All you should smell is that new car smell which is not musty. If you had an older car I'd say check the air filter, even still might be a good idea.
Old Nov 5, 2006 | 08:30 PM
HEMI-MINI's Avatar
HEMI-MINI
musty = BAD
Sounds like the stealer...errr...dealer is trying to justify a problem they don't want to fix or know how to fix.
Old Nov 5, 2006 | 08:34 PM
not-so-rednwhitecooper
you have something in your ductwork somewhere.
the machine they put in your car was an ozone generator. ask if they replaced your air filter or not (I would hope they tried that) if they have and the ozone generator does not work, ask for them to do a chemical treatment on the ductork. it involves spraying in a chemical deodorizer right in the vents.
Old Nov 5, 2006 | 08:53 PM
Edge's Avatar
Edge
AdMINIstrator
Merged the two threads (and two starting posts) on the same topic
Old Nov 5, 2006 | 09:03 PM
ma78's Avatar
ma78
Thanks Edge. And I love your work with Bono.
Old Nov 5, 2006 | 09:13 PM
Old Nov 5, 2006 | 09:25 PM
SMC's Avatar
SMC
Wow thanks for the quick respond, I am a non smoker and one wants smokes in there.The carpet is always dry and never run on circulate the air.
I had this before on my the other car ( Japanse car ) with the same odour and was removed by a fresh spray of chemical on the blower and filter changed . Unfortunately our dealer sticks to BMW recommendations which its sucks and now they are waiting another cleaning machine to do the job and that means no fresh air till..............
Old Nov 5, 2006 | 11:52 PM
you can get a kit and do it yourself.
its not hard, just make sure you wear a dust mask or respierator and rubber gloves when doing it, the stuff's nasty.
Old Nov 6, 2006 | 07:21 AM
ScottinBend's Avatar
ScottinBend
Is this a new car or used? If used, did you check to make sure it wasn't a water damaged one?
Old Nov 6, 2006 | 08:05 AM
Edge's Avatar
Edge
AdMINIstrator
Actually, that is "The Edge", I am just Edge. Also, his name is fake... mine is at least based upon my real name.
Old Nov 6, 2006 | 11:32 AM
200-OK's Avatar
200-OK
Strange coffee-like odor...
Hmmm... the only odor I've ever had in my 2006 MCS is a strange coffee-like odor...
Of course, that could be related to the "Venti" Starbucks that spilled all over my passenger carpeting...
Seriously, this doesn't sound normal to me. I had something similar in a previous car. Changing the interior air filter solved my problem...
Old Nov 6, 2006 | 11:58 AM
DixonL2's Avatar
DixonL2
Mini had some bad experiences chemical cleaning the vents and interiors on some cars (owners sensitive to chemicals) but it sounds like your car's venting or carpeting needs a cleaning with something other than ozone.
Mine smells like a "car", actually a pretty new-ish car, nothing musty or old-socky about it. 2 other non-new Minis I've been in were the same. Kind of blows the "they all do that" theory.
Old Nov 6, 2006 | 12:16 PM
lotsie's Avatar
lotsie
My Cooper tends to smell like dog
Mark
Old Nov 6, 2006 | 12:23 PM
OmToast's Avatar
OmToast
My '03 smells like whatever discretion/indiscretion I exercised the last time I was in the vehicle. So if I wear great purfume, that's what my car smells like. If I cannot find the dog's chewey stick, my car smells of soggy rawhide the following day. And if I leave a half-eaten bag of Doritos in the door pocket... you get the idea.
Old Nov 6, 2006 | 12:49 PM
Wesmonster's Avatar
Wesmonster
Febreeze
My last vehicle had the same problem, changed the cabin filter but no change in mustiness. I set the climate control to fresh air and set the fan on high and sprayed Febreeze into the air intake at the base of the windshield. Most car wash/detail shops have similar solutions. If you park your car outside I'd also check to see if leaves & debris migh be falling into the cowl vents at the base of your windshield. If so, this might be a source of moisture in your system.
Old Nov 6, 2006 | 02:33 PM
miniGarfield's Avatar
miniGarfield
we have two minis in the house and I've never heard of this before!
