Drivetrain wide band 02 sensor/gauge recomendations
Old Nov 3, 2006 | 04:49 AM
SpiderX's Avatar
SpiderX
I want to add one to my car for monitoring A/F...... recomendations for something I can mount anyone......
TIA
Old Nov 3, 2006 | 05:15 AM
PoonRacing's Avatar
PoonRacing
I got Innovate LC1 on mine, the hard part is try to found to good place to weld the bung for the sensor.
Old Nov 3, 2006 | 05:37 AM
MSFITOY's Avatar
MSFITOY
TIA
I've been very happy with the PLX that I got from M7...In retrospect, I should've spend a little more and got the logger version...
Old Nov 3, 2006 | 05:44 AM
latte hiatus's Avatar
latte hiatus
How much did you pay for the welding of the bung?
I've heard good things about the LC1 w/X16 gauge as well, but there are so many options out there that I haven't formed a solid opinion yet.
Old Nov 3, 2006 | 06:09 AM
MSFITOY's Avatar
MSFITOY
Welding the bung is no big deal...I had one put on both my Miltek and Megan header in a good location that's not interfering with anything...my guy did it for $25 each...
Old Nov 3, 2006 | 06:18 AM
Soul Coughing's Avatar
Soul Coughing
i ran a plx-250 into the original narrow-band bung... and then used the plx to give the ecu its NB requirements
I just made sure to use the same ground the ecu used, so that the information was more relavent! I'm now about to take apart all my handy work to put it in my s2k
Old Nov 3, 2006 | 06:28 AM
MSFITOY's Avatar
MSFITOY
I've thought about that...can you elaborate on "how to" do that?
Old Nov 3, 2006 | 10:54 AM
Bahamabart's Avatar
Bahamabart
I was looking at one of these -
AEM Gauge-Type Wideband UEGO Controller
I hadn't thought about it at all but thought that you just replaced the stock 02 sensor with the new one and that the wiring allowed you to plug the cars into it. Like I said didn't give it anythought.
Old Nov 3, 2006 | 12:48 PM
cooper99's Avatar
cooper99
Please excuse my ignorance, but what's the big advantage about having a wideband O2 sensor? Why wouldn't a cheap $50 dollar electrical lean/rich gauge do the job? I have been looking into gauges recently, and I have noticed that cheap lean/rich gauges cost $40, and a cheap wideband A/F with digital gauge costs $400+...?
Old Nov 3, 2006 | 05:34 PM
SpiderX's Avatar
SpiderX
when you custom tune the ecu (I have a Unichip) you need more resolution in your data than pass/fail. the wideband gives you that.....
Old Nov 3, 2006 | 07:00 PM
Trickle X's Avatar
Trickle X
I use the AEM & it works well....You can log with it too, but it just has a pin out for serial, so you would need to capture the data via mr lappy or pda. The downside is it only reads down to 10 on the rich scale. I found it to be the most resonable priced guage, and it looks like a gauge to.
Old Nov 3, 2006 | 07:12 PM
chuckt's Avatar
chuckt
Anything wrong with the AutoMeter 4378 or the Bosch sensor it comes with?
Includes high-quality Bosch wideband O2 sensor
Display data in Lambda or numerical A/F ratio
User programmable range...
Old Nov 3, 2006 | 10:03 PM
cooper99's Avatar
cooper99
^^It appears to be a great gauge, but it probably costs upward of $300.
Old Nov 3, 2006 | 10:06 PM
cooper99's Avatar
cooper99
Correction: $379.99
http://www.jegs.com/webapp/wcs/store...tegoryId=10625
Old Nov 3, 2006 | 10:24 PM
MarioKart's Avatar
MarioKart
Vendor
How does the color match? I have the Cooper S dual gauges Boost/Volt. Do you think I can get the color to match the OEM look. I had to mess around with my new pod gauges to get them brighter.
M
Old Nov 4, 2006 | 06:02 AM
Bahamabart's Avatar
Bahamabart
I found the aem on ebay for $242.00 plus shipping.
http://cgi.ebay.com/ebaymotors/AEM-6...QQcmdZViewItem
Old Nov 4, 2006 | 06:24 AM
saifa's Avatar
saifa
http://www.fjoracing.com/products/WBAFR/#
Thats the line we carry at work (as well as AEM). They are not the cheapest but work very, very well.There are options for gauge packages as well as dataloging. There display can be either gauge style or a led style.
Seann
Old Nov 4, 2006 | 07:25 AM
Soul Coughing
I worked out what the 4 wires did, cut the sensor line, soldered in the new wire from the PLX that goes to the ecu. I then built a resistor series to fool the heater element of the plug to think that it was heated...
What i did at first because i was lazy was tape the the original 02 sensor to the body of the car.... so it kept the heating part working while intercepting the sensor wire with the plx... Its just not as 'clean'
I found where the ecu grounds to the body, and ground it to that. Built a relay to turn on when original plug did and i was set! To be honset the hardest part is removing the original o2 from its bung. They tend to weld themselves to the exhaust...
Old Nov 4, 2006 | 03:07 PM
pmello's Avatar
pmello
Could you describe the resistor setup (values) etc. I have an AEM UEGO and would like to try using its narrowband output wire to run the ECU.
Old Nov 4, 2006 | 04:46 PM
MSFITOY's Avatar
MSFITOY
Wow...you're over my head I hate to admit...can you do a schematic?
Old Nov 5, 2006 | 06:33 AM
Soul Coughing
sure, ill get you the parts list i got from radioshack and a pic of how i soldered it all
Doc Pain
Mar 10, 2021 04:50 AM
penguinplf
Oct 11, 2015 07:36 PM
ludrof11
Sep 27, 2015 01:46 PM
smbmkay
Sep 11, 2015 09:45 AM
