Interior/Exterior Where does this go?
Old Oct 27, 2006 | 11:57 AM
JJ Blue's Avatar
JJ Blue
Where does this go?
There is a small plastic plug to the right and down from the windshied washer reservior. Does this lead to the cabin? Can I run my driving light switch wires through here?
Old Oct 27, 2006 | 12:23 PM
Partsman's Avatar
Partsman
Legion_of_Doom
I think you mean the brake master cylinder reservoir.
I pulled that plug and there is more sheet metal behind it. I stuck a coat hanger in there and the only place it went was down. It may eventually lead to the cabin, but not directly.
Old Oct 27, 2006 | 12:38 PM
JJ Blue's Avatar
JJ Blue
Partsman
Good thing I didn't put any washer fluid in there . What was I thinking. Hey thanks for the info. So back up the the difficult to reach grommet. Oh well.
Thanks again.
Old Oct 27, 2006 | 12:39 PM
JJ Blue's Avatar
JJ Blue
Dang I created another reply. This is not a good day.
Old Oct 27, 2006 | 01:46 PM
herbie hind's Avatar
herbie hind
Originally Posted by JJ Blue
Partsman
Thanks again.
dude; on the ifrewall you'll find a red wire(big) going to your pos. battery post. (next to airbox). plsae your wires on a coathanger and run them on top of the big red wire. (bend the hanger over at the leading edge to form a small loop.; this will prevent gouging any existing wiring. this will put you right under the wheel. run the steering wheel full up adjustment;grasp plastic piece under wheel at centertop and left top and pull down this will swing down (hinged) . there's your wire!!
Old Oct 27, 2006 | 02:16 PM
JJ Blue's Avatar
JJ Blue
herbie hind
Thank you for the tip. The other posts on installing the driving lights were not very clear about this part of the install.
Herbie you rock. I owe you one.
