There is a small plastic plug to the right and down from the windshied washer reservior. Does this lead to the cabin? Can I run my driving light switch wires through here?
I think you mean the brake master cylinder reservoir.
I pulled that plug and there is more sheet metal behind it. I stuck a coat hanger in there and the only place it went was down. It may eventually lead to the cabin, but not directly.
Partsman
Good thing I didn't put any washer fluid in there . What was I thinking. Hey thanks for the info. So back up the the difficult to reach grommet. Oh well.
Thanks again.
Partsman
Thanks again.
dude; on the ifrewall you'll find a red wire(big) going to your pos. battery post. (next to airbox). plsae your wires on a coathanger and run them on top of the big red wire. (bend the hanger over at the leading edge to form a small loop.; this will prevent gouging any existing wiring. this will put you right under the wheel. run the steering wheel full up adjustment;grasp plastic piece under wheel at centertop and left top and pull down this will swing down (hinged) . there's your wire!!
herbie hind
Thank you for the tip. The other posts on installing the driving lights were not very clear about this part of the install.
Herbie you rock. I owe you one.
