Drivetrain Changed Bypass Valve
Old Oct 25, 2006 | 02:06 PM
COR BLMY's Avatar
COR BLMY
I just finished the install ot the Detroit Tuned BPV
EDIT >>> I know I said TB ... SORRY !!!
WOW !!!
Now some back ground:
I Did VGS some time ago and was quite happy.
Over the last couple of months I had much lower vacuum than before. Thought that might be a hose issue.
I took the IC off and checked all hoses... seemed OK
Decided to do the DT BPV
look at my BPV as removed
The DT BPV had a butterfly that shut tight ... NO light gap
I did a ECU reset
Now I am back to 10 lbs + of vacuum
and the the car feels GREAT now
As you can FEEL the BOOST
Gets my
Old Oct 25, 2006 | 02:16 PM
MiniMacPR's Avatar
MiniMacPR
Old Oct 25, 2006 | 02:23 PM
COR BLMY's Avatar
COR BLMY
Thats how excited I was ... YES ... By Pass Valve !
OK so now my question is can I change a thread name ?
Old Oct 25, 2006 | 02:25 PM
MiniMacPR's Avatar
MiniMacPR
LOL! , sorry, I don't know how you change a thread name...
Congrats on your renewed boost!
Old Oct 25, 2006 | 02:58 PM
COR BLMY's Avatar
COR BLMY
Thanks "Mr. NAM" for correcting my thread name
Old Oct 25, 2006 | 03:04 PM
stevecars60's Avatar
stevecars60
WOW !!!
I did a ECU reset
Gets my
Were you getting a CEL?
Old Oct 25, 2006 | 03:30 PM
COR BLMY's Avatar
COR BLMY
No CEL ...
Old Oct 25, 2006 | 04:02 PM
herbie hind's Avatar
herbie hind
WOW !!!
I did a ECU reset
Gets my
wow; that's way worse than mine was.
Old Oct 26, 2006 | 06:54 AM
MiniMacPR's Avatar
MiniMacPR
Is there a possibility that the VGS could have caused your OEM valve to get like that?
Old Oct 26, 2006 | 07:08 AM
pberry51mini's Avatar
pberry51mini
No Fear Gear
Were you thinking that it caused the butterfly to shrink?
No, this is just sloppy parts and workmanship from the factory, that all fell within the tolerances they had allowed.
The Detroit BPV is the only way to go.
Old Oct 26, 2006 | 07:12 AM
Dr Obnxs's Avatar
Dr Obnxs
Absolutely not!
The BPVs are known to be bad.... crappy part with crappy quality. And if you want to know what these two items do (Modded BPV and VGS), and how they effect the car, read this post. It's too long to retype.
But FWIW, you can just reset the stop-screw and get your valve back to normal. Use some thread lock, and it's good to go!
Matt
Old Oct 26, 2006 | 07:15 AM
Dr Obnxs's Avatar
Dr Obnxs
This one always gets me...
This wasn't invented by Chad at DT. It was first done by Ryan (RyePhile here) and went by the name of RyeFix II. I guess I've just been around long enough to have seen the history, and how history forgets.....
Matt
obehave's Avatar
obehave
You folks do know you can adjust this yourself, in about 5 minutes......for free??
Edit: What Matt said
Old Oct 26, 2006 | 07:18 AM
Dr Obnxs's Avatar
Dr Obnxs
Guess not....
But what they heay, if you buy the valve from Chad, you don't have to worry about breaking the tabs when you change the spring....
Matt
Old Oct 26, 2006 | 07:20 AM
obehave's Avatar
obehave
Matt
Forgot about the springs. Never found that bit useful.
Old Oct 26, 2006 | 07:21 AM
pberry51mini
No Fear Gear
Matt
What I said earlier without the drama.
Paul
Old Oct 26, 2006 | 07:26 AM
MiniMacPR's Avatar
MiniMacPR
My thought process was that since he had experienced a loss of vaccum/boost at some specific point in time after the VGS was done, the added air pressure dump from post S/C could have damaged the weak/cr$ppy OEM spring from the added velocity of the valve opening/closing, therefore causing the valve to not close properly/completely, as per the posted picture. Then again, who knows what it was like before the VGS.
Thanks Dr.O , I've previously read over the referenced post and other related threads and I (think) I understand what the mod is for and how it works.
And I also get the general consensus that the OEM BPV's are cr$ppy at best.
BTW, the butterfly didn't shrink , it's just not fully closed.
Last edited by MiniMacPR; Oct 26, 2006 at 08:34 AM. Reason: Edited for clarity (or lack therefof)
Old Oct 26, 2006 | 07:39 AM
COR BLMY's Avatar
COR BLMY
This was not against the stop when removed
The butterfly cioud be pushed closed but this is the position that it would return to.
Could VGS have weekened the spring .... maybe
but the valve that is actuated by vacuum shoud be able to handle vacuum
anyway I am now way better
Old Oct 26, 2006 | 08:04 AM
sanddan's Avatar
sanddan
What was your vacuum and boost numbers before and after the BPV change?
If the BVP is bad, would the idle vacuum be low? Like 4 to 6 in Hg?
Old Oct 26, 2006 | 09:18 AM
pberry51mini
No Fear Gear
No, shrink would be my pants since quitting the gym.
Old Oct 26, 2006 | 12:26 PM
gt6's Avatar
gt6
How? Any links other than Matt's above? His explains how it works but no info on an adjustment.
Old Oct 26, 2006 | 01:24 PM
Dr Obnxs's Avatar
Dr Obnxs
To adjust the stop
just remove the valve, and turn the set screw. In later valves, they use some good thread lock, so you have to apply a little heat to get it to give.
To modify the spring, I took the diaphram apart, and then stretched the stocker. IT's not the same as the spring in the DT valve, but it gives you some of the effects (earlier closing, but it will open all the way, and doesn't slam closed as much under light throttle driving). Taking the diaphram apart is a bit of a pain, and having 3-4 small jewelers screwdrivers helps (flat blade, not Phillips!). I think the Yo-Yo Chronicals has info on this as well. But that is a novel of a thread!
The VGS won't trash the spring.... Vacuum is what fights to open the spring, and boost forces it more closed. Higher boost doesn't really move too much in the diaphram... Sound like his just gave it up, like many have before!
Matt
Old Oct 26, 2006 | 01:49 PM
MiniMacPR's Avatar
MiniMacPR
Matt
Yep, right as always Doc (or almost always, just ask Chow ). Thanks for clearing up my erroneous theory. Somehow it made sense in my head.
Old Oct 26, 2006 | 01:58 PM
Dr Obnxs's Avatar
Dr Obnxs
In the semiconduct industry...
whatever vendor is standing next to whatever broke is blamed! The two are connected, so it was a good guess. And who knows, maybe I'm wrong again!
Matt
Old Oct 26, 2006 | 04:41 PM
Soul Coughing's Avatar
Soul Coughing
i did the same thing to my bypass valve.... it didnt take long and i felt like i had accomplished something... as well as learning more about the car
i 'felt' a difference afterwards, but could have been me wanting to feel something.
Do it! you wont regret it
