Different size lug bolts??
I ordered my wheels from an onlie store and they said I need different size lug bolts for the wheels to fit. They sent me them but are they really necessary?? Have you heard of this before??
Yes - they're not crazy or scamming you. Some wheels have a different "taper" to the lug holes (the conical shape at the bolt head) and if you use the wrong lugs the lug won't seat correctly. It either sits on only the shoulder of the bolt, unevenly distributing stress and causing, in effect, the lug to become less tight, or in the case where the taper is narrower on the stock lug bolts, you'll actually "drill out" the other wheel with the stock lugs.
Other wheels simply require a longer lug bolt. Either way, use the correct lugs for the wheel (length, taper) and the hub (thread).
I slipped the bolts into the tires tonight. How tight are they supposed to be in the holes of the rims. They is about a 2mm gap all around the bolt to the edge of the wheel bolt. Is there any way to tell if these are the right bolts?? BTW it says M12x1.5 on the lug nuts.
Sounds like you're going through the same crap I am. Appearently Edge racing wasn't aware that in August Mini randomly decided to change the bolt holes to a 14x1.5 size from the previous 12x1.5 size. Unfortunatly the holes on the wheel are only big enough for a 12x1.5 bolt, so I can't mount them, even with different bolts. 300 bucks for next day air to get the wheels here before I leave town and I can't even mount them.
.They're sending me a stud conversion kit to remedy the problem, but i'm thinking of just drilling out the holes on the wheels to accomodate a 14x1.5 bolt. Has anyone ever tried drilling the bolt holes on a wheel? If so, anything I should be concerned with? Other than the obvious, voiding the wheel warranty, etc.
*Edit* Further research has turned up that it's an M14x1.25 bolt not an M14x1.5 bolt. Sorry for the confusion. Thanks to Alex from Tire Rack for clarifying this.
If I ordered the M14 x 1.25 locks from the dealership, should they fit?? The holes on my rims were plenty big enough with the M12s. Do I need to be worried about the length of the locks??
I'm not sure I understand, you used M12 bolts on your wheels even though they didn't screw into the hubs properly? How did you do this? You should buy wheel locks for whatever size your hub requires, if it's the older design, then M12, if newer, M14. I don't see any reason why the dealers wheel locks won't work on your car. As long as the bolt turns into the hub 5-6 turns and stays there it's doing it's job. Most wheels can use the stock wheel bolts, unless they're some crazy offset.
patsum
26
May 29, 2021 06:29 PM
Sep 3, 2015 10:29 AM
