Hub Centric Ring Size ?
Old Oct 20, 2006 | 06:30 PM
Giants9595's Avatar
Giants9595
I got some hub sentric rings for the new rims and tires I got mounted for the car I am taking delivery of next weekend. The tire place gave me rings that said:
Wheel Bore Size: 73mm
Vehicle Hub Size: 56.15mm
I searched on here and saw that the mini's hub is 56.1mm so will these work being 56.15? Also they are plastic, will that be ok??
Old Oct 20, 2006 | 06:35 PM
dave's Avatar
dave
pug poo picker-upper
56.15 is fine That's .05 mm of clearance (which is tiny) between the inner diameter of the ring and the outer diameter of the hub.
Metal would be preferred, but the plastic ones could hold you over until you source some metal ones.
Old Oct 20, 2006 | 09:19 PM
XAlfa's Avatar
XAlfa
or, as they say in the business, "fiddy-sic-dot-one."
Old Oct 26, 2006 | 07:17 PM
DixonL2's Avatar
DixonL2
Plastic's great, but not at the track (it'll eventually melt, and is hard to get off everything).
You can run w/o hubcentric rings, but can get some wobble if you're not careful evenly tightening/torquing the lugs (while car is in air or *lightly* on the ground and jack).
Old Oct 26, 2006 | 07:20 PM
mitchman's Avatar
mitchman
Yes, those will fit the Mini.
But I agree with DixonL2. If you tighen the lugs carefully, you don't even need hubcentric rings most of the time. There are exceptions, but I've never had a problem and I'm pretty **** about such things.
NickBchillin
Oct 5, 2015 05:11 AM
minimofo
Sep 30, 2015 12:26 AM
pkrysR56
Sep 19, 2015 07:58 AM
sempaipaul
Sep 18, 2015 03:05 PM
Manny_cooper
Sep 9, 2015 05:17 PM
