R50/53 Cabin Filter delete?
Old Oct 9, 2006 | 10:28 PM
ThereIsNoSpoon's Avatar
ThereIsNoSpoon
Any reprecussions to removing the cabin filter and operating the vehicle and it's environmental control without it?
It was easy to yank out when i went to change it but seems to be a pita to stuff the new one back in. And I could swear that it blows harder without it
Old Oct 9, 2006 | 10:45 PM
Dr Obnxs's Avatar
Dr Obnxs
Gunk will go farther into your vent system...
so eventually it will get dirtier in places that are harder to clean, but removal of it should also allow for more air flow......
Whatever makes you happy!
Matt
Old Oct 10, 2006 | 04:45 AM
mdsbrain's Avatar
mdsbrain
Matt
Just what I was thinking.
Removing it is super easy. Its in the passenger footwell. Pull the cover off (it snaps off on the long side) then pull the filter out. I just replaced my carbon filter yesterday.
Also after replacing the filter the air smells better and blows a tad better.
Old Oct 10, 2006 | 05:54 AM
ProfessorDave's Avatar
ProfessorDave
Given how dirty that thing gets, I'd prefer to keep it in. Not only for cleaner air to breathe, but also to keep the interior less dusty.
ThereIsNoSpoon, have you looked into a less dense filter? Maybe the paper option is less restrictive?
As always, watch out for those agents!
Old Oct 11, 2006 | 11:12 AM
acitydweller's Avatar
acitydweller
Removing the filter allows for more airflow. The cost of doing so is probalby not worth it.
Old Oct 11, 2006 | 11:20 AM
BECOKA's Avatar
BECOKA
I like to breath clean air and don't really like the dust that piles up over time. I will just end up changing it often to keep the resistance for air flow down.
Old Oct 11, 2006 | 12:03 PM
Wesmonster's Avatar
Wesmonster
replacement filter
I wonder if K&N makes a replacement filter? Probably add 2 to 3 BTUs to your air conditioner.
Old Oct 11, 2006 | 01:00 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
MicronAir makes a replacement filter. Same sort of thing as the stock with the active carbon.
Old Oct 11, 2006 | 01:09 PM
DaCrema's Avatar
DaCrema
better airflow until the AC stops working because the blower clogged. Put a new filter back in. Change it twice a year.
Old Oct 11, 2006 | 10:58 PM
dix's Avatar
dix
Replace the filter. It makes the interior smell fresher and is healther for you and your passengers. I replace mine twice a year, but I also live on a country road.
Old Oct 12, 2006 | 05:48 AM
DaCrema's Avatar
DaCrema
Just a thought for the new owners...
for the new owners who did not opt for the Auto AC with the carbon filter. The filter is the same size and you can use either filter. If you suffer from alergies there may be some advantage to spending the extra cash for the carbon filter. On a simular note, I have the auto AC and run the regular filter for the winter season.
Please forgive me if you know this. It just occured to me that a new owner may not understand the two filters are interchangeable depending on the need of the owner.
John
Old Oct 12, 2006 | 09:11 AM
BECOKA's Avatar
BECOKA
John
I did not know this and it is good to know. Of course I got the Auto AC but still good to know.
Old Mar 31, 2007 | 07:34 AM
muy_mini's Avatar
muy_mini
Re: carbon filters / allergies
Any pollen/particulate that is large enough to be trapped by the filter, plain paper or one with activated charcoal, will help allergy suffers. The charcoal [carbon] ABSORBS chemical vapors and odors and has little to do with helping alleviate typical allergy symptoms. IMHO, the amount of surface area in the activated charcoal that cabin filters contain is probably so small that it's saturated in a very short period.
-Barry / 10 Ball
Old Mar 31, 2007 | 10:01 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I have never changed the a/c filter in my car's 4.5 year life. I guess I should do that soon.
Old Mar 31, 2007 | 10:13 AM
Eric_Rowland's Avatar
Eric_Rowland
For those who have replaced, what's the cost, and where did you get it (i.e. local dealer or Classic, etc.) TIA
Old Mar 31, 2007 | 10:30 AM
ScottRiqui's Avatar
ScottRiqui
Well, since yours is an extreme case, you're in a good position to tell us if you notice a big difference afterwards (does the air smell cleaner/different, is there significantly more airflow from the vents, etcetera).
Of course, if you ever took your car in for the free scheduled maintenance with the dealer, the cabin filter is included in at least the first scheduled maintenance, and perhaps others, so they should have changed it for you.
Old Mar 31, 2007 | 10:40 AM
NMgokart's Avatar
NMgokart
Heh...filter. Who knew.
Just went out to check mine, and ThereIsNoSpoon, you are quite correct! That thing is a major PITA to put back! And mine snapped the plastic frame in several places. Guess it's time for a new one!
Old Mar 31, 2007 | 06:13 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I never did the free service at the dealer. They are a good 250 miles away, and I need my car for work/college and such so I couldn't have had it towed. My a/c is broken at the moment, the freon is gone. It still blows air though, and the heat still works I think.
Old Apr 1, 2007 | 06:41 AM
muy_mini's Avatar
muy_mini
I suspect, no proof, that my filter did not get changed at the first service. I'll ask at my next and final freebee visit before the warranty expires.
I removed my filter yesterday and blew it out with compressed air. Great to do on a windy day and upwind of your least favorite neighbor. I was surprised at the amount of dust it had trapped. Cracked the plastic frame on the filter while trying to flatten it out and clean the folds, but it reinstalled just fine. My filter, '05 MCS, was a fuzzy type of fabric [on the upstream side] and NOT paper.
-Barry
Old Apr 1, 2007 | 01:26 PM
rwkeating's Avatar
rwkeating
I always thought filters on car system ACs/heaters were a bit funny. Sure they keep things clean inside, but open the windows and anything in the air comes flooding in anyway. Do folks drive around with there windows closed all the time to keep the interiors clean? I'll confess that after cleaning the interior I sometimes keep the windows closed more often than usual ... but that lasts only a little while
Old Jan 23, 2008 | 08:17 AM
Coolny29's Avatar
Coolny29
Does anyone have instrucctions on how to change the pollen filter? Thanks
Old Jan 23, 2008 | 08:25 AM
MUShadd's Avatar
MUShadd
My dealer refused to change my filter until the 30,000 miles service, which is about $500. Which is one of the many reasons I will no longer do business with them, and will change the filter myself.
Old Jan 23, 2008 | 09:11 AM
Dan00Hawk's Avatar
Dan00Hawk
Yep, with how often my windows are open anytime the temps are between 50 and 85, I don't think I'd miss a cabin filter aside from the winter (not much pollen then), and the few times it's hot enough to use the AC with the windows closed.
Old Jan 23, 2008 | 01:23 PM
Dr Obnxs's Avatar
Dr Obnxs
Check post #3 in this thread!
Old Jan 23, 2008 | 09:23 PM
Ancient Mariner's Avatar
Ancient Mariner
Definitely worth changing! Bosch makes both the carbon and standard style, I believe, so aftermarket autoparts shops should carry them. I think Qualitee (a French co. I think) offers a cheaper version.
My car is 6 years old, and I've changed it 5 times. It gets easier with practice, and after blowing out the first one, I'm a true believer.
Roughly $30.
