JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW Engine upgrade kit, does that include a NEW JCW Supercharger?
Old Oct 1, 2006 | 05:36 PM
CDMINI's Avatar
CDMINI
...or do they just retrofit the JCW upgrades to the standard supercharger on the S? Who know the answer to that question?
Old Oct 1, 2006 | 08:45 PM
shinka's Avatar
shinka
From what I can tell, the 02-04 models have a different model supercharger than the 05-06 models. So the 02-04 JCWs get a supercharger upgrade, while the 05-06 JCWs just get the new pulley (plus headers, intake, exhaust, etc).
Old Oct 1, 2006 | 09:03 PM
pberry51mini's Avatar
pberry51mini
No Fear Gear
Zat so, interesting.
Paul
Old Oct 1, 2006 | 11:04 PM
MINICHEF's Avatar
MINICHEF
For My Money I Got New Cyl. Head; New Coated Sc; Air Filter Asembly; Cat Back Exhaust; Re-maped Ecu; Bigger Injectors;some Badges And Stickers.
Old Oct 2, 2006 | 08:32 AM
shinka's Avatar
shinka
Well, you'd probably know better than I. I've heard diff things.
Old Oct 2, 2006 | 01:26 PM
CarterMD's Avatar
CarterMD
It's very easy:
JCW-200PS:
- coated 5th Gen. Supercharger 58mm Pulley
- modified cylinder head
- exhaust
- badges
- JCW-software (200HP)
JCW-210PS:
+ 380cc injectors
+ jcw air filter housing and filter element
+ JCW-software (210HP)
You get every time a new supercharger, it doesn't matter what supercharger you currently have. BMW does not change pulleys because of warranty !
Old Oct 2, 2006 | 02:55 PM
forestcrump's Avatar
forestcrump
I could be mistaken but I thought the 06's MCS all had the same supercharger. Could anyone clarify this for me.
Forest
Old Oct 2, 2006 | 02:58 PM
Dr Obnxs's Avatar
Dr Obnxs
The rotor coatings
used to be different between the S and JCW. Now they are the same. The SCs have different diameter pulleys, and that's it.
Matt
Old Oct 2, 2006 | 03:00 PM
CarterMD's Avatar
CarterMD
'06 MCS all have the same supercharger, thats right !
Prior to 7/2004 the supercharger was "only" 4th generation and therefor was not coated. The JCW-kit had the 5th generation supercharger as upgrade.
After 7/2004 the supercharger was coated, therefor 5th generation, but with the standard pulley. The JCW-kit uses the 5th gen supercharger again, but only with a smaller pulley.
Old Oct 2, 2006 | 03:01 PM
forestcrump
Thanks,
Thats good for me. I love my M7 pulley! I had to say that.
Forest
Old Oct 2, 2006 | 03:43 PM
chows4us's Avatar
chows4us
Edited. NM, your correct. I had 04 JCW and it had the upgraded SC. Correct.
Old Oct 2, 2006 | 10:45 PM
JPMM's Avatar
JPMM
So what does a 03 MCS JCW car have? A smaller pulley for more boost? What is the SC "coating" ?
Old Oct 3, 2006 | 12:50 AM
CarterMD's Avatar
CarterMD
Yes, the pulley is smaller !
The coating, well.... i switched from uncoated to coated some time ago. I did not notice any boost increasement !
I think the coating is good for that the hot compressed air does not flow back between the shovels. Some tuners here in Germany did some tests and they said that in low rpm, i.e. 3000rpm, there is little more boost available.
Old Oct 3, 2006 | 08:43 AM
Dr Obnxs's Avatar
Dr Obnxs
It's
IT's a coating that is put on the rotors that wears away during initial use to get tighter tolerences. It reduces leakage around the rotors and is good for a few % in boost increase.
Matt
Old Oct 4, 2006 | 02:58 PM
dstrass's Avatar
dstrass
By how much (%) the JCW pully is smaller then regular S one?
Old Oct 4, 2006 | 03:01 PM
CarterMD's Avatar
CarterMD
About 12%, little less I think.
Standard is 65,0mm, the JCW is 58,0mm !
Old Oct 4, 2006 | 03:26 PM
dstrass's Avatar
dstrass
I am getting 10%
(65-58)x100/65=10.76%
Am I doing something wrong?
So why the aftermarket is selling higher reduction (15%), much higher sometimes (19%)?
Would'nt it effect reliability?
Old Oct 4, 2006 | 03:40 PM
Edge's Avatar
Edge
AdMINIstrator
I am getting 10%
Everything I've heard up to this point says that the JCW pulley is 14.7%.
Old Oct 4, 2006 | 03:43 PM
CarterMD's Avatar
CarterMD
Well, I have both here in front of me ! Standard is 65mm and JCW is 58mm... now calculate for yourself.
Over here in Germany we always messure in mm and not in percent. So we avoid any mistakes by calculating. JCW has always been 58mm, we measured several from when the kit startet to now.
Old Oct 4, 2006 | 04:24 PM
Edge's Avatar
Edge
AdMINIstrator
I'm only said what what I've read, I'm not claiming from personal experience that it is correct! If the information is wrong, the information is wrong. I have no qualms about that.
Here's one place I probably got the idea:
Originally Posted by Webb Motorsports
I have personally installed over 400 15% reduction pulleys, and have not had a single issue with any of them. I have installed 4 pulleys greater than 15% reductions, and have had issues with all of them. Based on this, the preliminary testing we did, manufacturer discussions, and the fact that a few months after we came out with a 15% reduction recommendation John Cooper Works came out with a pulley on their supercharger that was within .03" of a 15% reduction, I can confidently say that the 15% reduction pulley is the best choice for not only performance, but reliability as well.
Link - Webb Motorsports
But I've seen it elsewhere too. Oh well - if it's 12%, it's 12%! I have no problem being wrong. Did the standard MCS pulley size change between 2004 and 2005? Just wondering.
Old Oct 4, 2006 | 04:31 PM
Mini_Crazy's Avatar
Mini_Crazy
Measurement is. . .
Measurement of pulley diameter is based on chord diameter of the belt wrapped around the pulley, which is a (consistant) larger dimension than measuring the pulley directly. I believe Doctor O published the formulas in an older thread. The smaller chord diameter of the JCW pulley provides just under 15% increase in blower speed compared to standard.
Manufacturers of Micro-V belts publish standard tables on how to calculate this stuff, so we don't need to re-invent it here.
Old Oct 4, 2006 | 04:59 PM
chows4us's Avatar
chows4us
This used to be a sticky https://www.northamericanmotoring.co...ghlight=dispel
Dispelling the myths.
Old Oct 4, 2006 | 06:47 PM
Edge's Avatar
Edge
AdMINIstrator
OK, so it's 14.3%. I knew it was something close to 15% but a bit less. I probably was thinking of the 0.7% less and thought somehow it was 14.7.
Old Oct 4, 2006 | 11:49 PM
Tit's Avatar
Tit
Pretty sure the zorst is only a cat back, no headers...
iamcamkeenan
Aug 10, 2015 03:31 PM
marendt428
Aug 8, 2015 04:44 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
