R50/53 Where on the car can I find the VIN?
Old Sep 28, 2006 | 11:16 AM
ScottRiqui's Avatar
ScottRiqui
I have one of the convertibles on order that was accidentally given a 2007 VIN code.
I have since been given a "new" VIN (same as the old VIN except for the year digit and the check digit), but it appears that MINI did not have to re-build the 147 affected cars.
So, this sounds like they figured out how to change the existing VIN tags on the cars. The affected cars that had already made it to the states did NOT have to be shipped back to the factory, so changing the VINs sounds like something that can be done at the VDC or at the factory.
When the car arrives, I'd like to make sure they changed ALL of the VIN markings, but I'm not sure where they all are. I know about the tag on the dash, the one on the right-hand strut tower under the bonnet, and the label in the doorjamb. I've also heard that there's one hidden behind the license plate, but I haven't taken the plate off of my wife's car to check.
I'm assuming the VIN is on the engine block as well, but not sure where. How about the chassis itself? Other body panels? Transmission/differential?
Any suggestions as to other places to check when the car arrives would be appreciated.
Thanks,
Scott
Old Sep 28, 2006 | 11:23 AM
krolyat's Avatar
krolyat
I'm not positive that MINI's do this - but on the windows etched in the glass.
>> from google = vin locations
Old Sep 28, 2006 | 11:26 AM
ScottRiqui's Avatar
ScottRiqui
I don't think that my wife's '06 MCSC has the VIN etched into the glass. I've seen a lot of MINI's that have it, but I think it's a dealer-performed option or something the owners did themselves with a kit.
One more place to check, though - thanks!!
Scott
Old Sep 28, 2006 | 11:28 AM
krolyat's Avatar
krolyat
No prob but that last link shows a sample car. Having the VIN etched on the glass also helps lower your insurance by a little bit depending on who your provider is.
Old Sep 28, 2006 | 11:34 AM
krolyat's Avatar
krolyat
http://www.kerrywilson.com/vin.htm
Very helpful also helps you read your VIN number.
Old Sep 28, 2006 | 11:35 AM
Gromit801's Avatar
Gromit801
Our VIN is on the manufacturer's plate on the driver's side door jamb.
Old Sep 28, 2006 | 11:36 AM
ScottRiqui's Avatar
ScottRiqui
Thanks again. I've tried Google, but can't find anything MINI-specific. That link in your first post is very generic, and basically points out that the VIN can be *anywhere* on the car. I'm trying to find out exactly where it is on the MINI so that I don't miss any when I check it.
Scott
Old Sep 28, 2006 | 11:47 AM
goldcountrymini's Avatar
goldcountrymini
Scott
I've only found 4 of them... boot, front left driver side glass. Driver side door & under the bonnet on the strut tower.
Old Sep 28, 2006 | 11:52 AM
krolyat's Avatar
krolyat
Also...I wouldn't go looking for this one (requires you to pull the plastic back/off) but there is def. one stamped inside the wheel well of the driver side.
"There are many other disclosed locations" that the dealer is willing to tell the title holder of the car. - local MINI dealer rep from the body shop
Old Sep 29, 2006 | 10:21 AM
Mishka's Avatar
Mishka
The last six digits of the VIN are the sequence numbers of your car in the production run. The numbers on your motor(and frequently the transmission) are usually just these last six digits so the 7th digit and check digit won't be there.
Dec 23, 2015 10:36 AM
nomar116
Aug 10, 2015 11:24 PM
1964geo
Aug 10, 2015 06:22 AM
