Miata wheels on an MCS?
Old Sep 22, 2006 | 07:08 PM
84im's Avatar
84im
I have 215/40-17s (older Borbet wheels) mounted my my V8 Miata. I want to mount them on my 2006 MCS. Will I need Mini sized hubcentric rings, or will they just bolt on?
Old Sep 22, 2006 | 07:41 PM
xizor's Avatar
xizor
don't know for sure, but I bought a set of kosei's from a miata owner and the included hub rings would not fit on my MCS, seemed like it was just 1mm off, but just couldn't fit on. ordered a set specifically for the MINI and it worked perfect. give it a try who knows
Old Sep 22, 2006 | 07:43 PM
SumWon's Avatar
SumWon
The hub diameter on the Miata is different than the MCS, it is smaller. Unless you have the hub opened up, its not possible to mount them, I tried.
Old Sep 22, 2006 | 07:53 PM
Eric_Rowland's Avatar
Eric_Rowland
Good to know. I know the MINI wheels fit on the Miata (and they look friggin' HUGE!), but hadn't tried the reverse.
Old Sep 22, 2006 | 08:01 PM
mmatarella's Avatar
mmatarella
Check offset too...
Old Sep 22, 2006 | 08:20 PM
kenchan's Avatar
kenchan
^^ yep, miata's i believe use 35-38mm
Old Sep 23, 2006 | 09:23 AM
84im's Avatar
84im
Thanks for the response. I don't know what the offset is, but it looks to be in the 35 to 40 mm range. I'll probably try to put one wheel on to see if it fits.
This isn't the wheel/tire combo that I eventually want on my MCS (I presently have the stock 16s), but since I plan on replacing the wheels/tires on my monster Miata with 15x8 wheels with 225/45-15 Hankook R-S2s, I thought I'd give them a try. I wonder if the 15x8 wheels (40 offset) and Hankook R-S2 combo would fit on my MCS.....
Old Sep 23, 2006 | 10:05 AM
Mineon's Avatar
Mineon
Actually the offset of most stock Miata wheels is 45mm, very close to the Mini stock offset. Some people do use numerically lower offset wheels on Miata though, but unless the Mini is lowered, the wheels should fit the Mini if they fit the Miata. As mentioned before the hub bore is slightly smaller on the Miata, so just remove the hubcentric rings to mount the wheels on the Mini. I switch several of my wheels back and forth between my Mini and my Miata.
-Keith
Old Sep 23, 2006 | 06:16 PM
84im's Avatar
84im
Well, I mounted one of my Miata's wheels on my MCS.....and it fits. My Miata doesn't have hubcenric rings.
The first thing I noticed was the wheel stuck out quite far. I checked the inside of the wheel for any numbers, and found the offset; 30mm. No wonder the wheel stuck out so far. Oh well, it was worth a try.
Old Sep 23, 2006 | 06:27 PM
84im's Avatar
84im
Here is a picture of the wheels.
Old Sep 23, 2006 | 06:32 PM
Tit's Avatar
Tit
The offset and wheel width would be the problems here...
Old Sep 24, 2006 | 01:56 AM
Mineon's Avatar
Mineon
Why would the wheel width be a problem? Those are probably 7" or 7.5" wide, and many people run a wheel that is that wide or wider without problems. The offset isn't ideal at 30mm, but the wheel width isn't a problem.
Old Sep 24, 2006 | 06:09 AM
kenchan's Avatar
kenchan
^^ i think tit meant if offset is aggressive, the width might be a problem.
like 35offset and 7" might not (probably not) work without some
dremeling if running the popular 215/45/17 size.
mineon- even if the stock offset if +45 on the miata's, they look super
tucked in (worse than corollas) so 35-38 would probably be the norm
for aftermarket wheels for them(?)...
Old Sep 24, 2006 | 10:25 AM
84im's Avatar
84im
With a 215/40 tire and a 30 offset-7.5 inch wide rim the outer edge of the tire lined up with the outer edge of the black plastic fender flare. Unfortunately, I didn't take any pictures.
Old Sep 24, 2006 | 10:35 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
i run et 35 with 7 inch wide wheels....and my car is slammed VERY low. No problems whatsoever.
Old Sep 24, 2006 | 11:57 AM
Mineon's Avatar
Mineon
I guess it all depends what you think looks good. I've had wheel/tire combinations (wider tires and wheels than stock with lower offset) on some cars that were pushed all the way out to the edges of the fenders and I thought they looked good and I got lots of compliments. To each his own I guess.
-Keith
Old Sep 24, 2006 | 05:04 PM
84im's Avatar
84im
I didn't think it looked bad (I actually thought it looked good), but I thought that the tire might hit the plastic fender lip at full shock compression.
Old Sep 24, 2006 | 08:30 PM
kenchan's Avatar
kenchan
what is your tire size? and did you dremel the rear?
if not, do you have camber adjustment on the rear?
Old Sep 24, 2006 | 09:07 PM
Rally@StanceDesign
tire size is 205/50 which is definitely shorter than stock....but my car is lowered enough that it's basically like most peoples lowered ride height with stock diameter tire setups.
The rear has been cut a little....but nothing big.
Old Sep 24, 2006 | 09:16 PM
elprofe's Avatar
elprofe
that miata looks huge next to the mini.
Old Sep 24, 2006 | 09:44 PM
OctaneGuy's Avatar
OctaneGuy
I put my 15" Flik Fuels from Edgeracing on my MCS that's lowered with HSports. I've got Falken Azenis in 205/50's and I scrape everytime I go over a speed bump or go into driveways.
I talked to a guy recently who said it was funny because he had the same Flik Fuels on his Miata.
I love the faster steering response of the 15's over larger wheels.
Richard
eatsleepautox
Oct 30, 2015 06:46 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
azntaiji
Aug 13, 2015 03:24 PM
nomar116
Aug 10, 2015 11:24 PM
dyeLucky
Aug 7, 2015 07:10 AM
