Solo crosspost : New Avon Mini sizing - comming soon!
Old Sep 16, 2006 | 06:42 AM
Alex@tirerack's Avatar
Alex@tirerack
check it out!
Alex
Old Sep 18, 2006 | 04:14 AM
GRMPer's Avatar
GRMPer
Woody and Angie will have them on their car at Nats...it might just be the hot tire!
Can't wait to try them out.
Per
Old Sep 18, 2006 | 06:48 AM
trick's Avatar
trick
Per
I'm really curious how these wear since you won't be able to swap these front to rear.
Old Sep 18, 2006 | 11:23 AM
gareno's Avatar
gareno
The rears will last forever!
Old Sep 18, 2006 | 04:48 PM
GRMPer's Avatar
GRMPer
I currently just run through fronts and have been using one set of rears. I rather get two at a time, rather than four.
Per
Old Sep 18, 2006 | 06:50 PM
trick's Avatar
trick
Wish I'd thought of that.
Old Sep 18, 2006 | 08:28 PM
JustGo4It_'s Avatar
JustGo4It_
The 225/50/16's will fit on all 4 corners with et42 rim's (SSR's). The new smaller profile will take care of the gearing disadvantage. The Avon's don't suffer from heat soak like the 710's do. They are a perfect concrete tire but I'm not sure they can get up to temperature with a single driver on asphalt. I hear rumor the compound has been tweaked for this new size, but you know how that goes...... My current practice set from last year has 95 runs, 57 on Atwater concrete.
Old Sep 19, 2006 | 06:28 AM
gareno's Avatar
gareno
According to the specs, and having to guess a little, as the new size isn't listed. The Avon will weigh 5-6lbs more per tire than the 215/40 Kumho. Thats quite a bit of extra rotational/unsprung weight.
Dec 23, 2015 10:36 AM
Mini'mon
Aug 16, 2015 04:15 PM
Mini'mon
Aug 16, 2015 12:47 PM
OutMotoring
Aug 6, 2015 09:32 AM
