Ventus Rs2 Z212 225/45/16 on Kosei K1s?
Old Sep 14, 2006 | 02:33 PM
gnhovis's Avatar
gnhovis
Reverse
Will the following fit on an '04 MCS with stock uspension? I have 16 x 7.5 Kosei K1 Racing rims and can get some Ventus Rs2 Z212 tires in size 225/45/16? Will they rub?
The Hankook website says they have a section width of 8.9 inches and a tread width of 8 inches. Compared to my Goodyear GS-D3 205/50/16s which they list as 8.4 inch section width and 7.1 tread width. If I'm reading the numbers correctly, I would expect the widest part of the tire to be .25 inches closer and the edge of the tread to be .45 inches closer to the suspension members, no? My uncallibrated eyeball says it might be close...
Will I need spacers? How do spacers work with hub-centric rims, do they extend the flange as well? I'll be using for occasional autocross and random track days. Any spacer recommendations? (size/brand/vendor) Thanks.
Old Sep 14, 2006 | 03:37 PM
Duane's Avatar
Duane
Spacers
Don't know on the tires, but H&R makes very good spacers
http://www.hrsprings.com/site/index.html
Old Sep 14, 2006 | 04:21 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Given your stock suspension you will be fine with the rims which have a +43mm offset. The tires will be fine for that size rim and for your MINI. No spacers needed. The 215/45-16 is smaller outer tire diameter than stock and width is not too wide.
You can confirm this all with Alex@tirerack.com. I think you might be buying from Tirerack??
Old Sep 14, 2006 | 07:03 PM
scobib's Avatar
scobib
5-8mm spacers are not hubcentric (at least none I have seen), as there's not enough material there to make it work. 15mm and larger usually do have a center that's machined to the OEM centerbore - at least H&R does.
I'd think you should be fine with that setup - might require 5mm spacers to clear the strut in front, though. I'm running 225/50R15's on 15x6.5 wheels with a +40 ET and no issues for autocross and track, though. Those are taller and the same width. Of course, I do have camber plates in the front to help them clear the fender lip... In the rear, they also clear just fine...
Keep in mind that the 225/45R16's are shorter than OEM fitments, I think...
Tire Rack doesn't carry Hankook, right?
Old Sep 14, 2006 | 07:19 PM
snid's Avatar
snid
225/45/16 or 215/45/16?
I'm running those wheels and tires in 215/45/16 with no problems on my Cooper with the JCW suspension upgrade.
Old Sep 15, 2006 | 06:43 AM
xizor's Avatar
xizor
I have that exact combo Kosei's and Z212 225/45/16 and no rubbing on MCS SS+ no lowerng
Old Sep 15, 2006 | 07:15 AM
gnhovis's Avatar
gnhovis
Reverse
Thanks for all the replies. I got them back and they fit fine. It's interesting the variations in the same size tires. My 205 Yoko AVS ES100s are about the same width at the widest part even though the tread width is probably an inch smaller. The Z212s seem very square shouldered, if that's a word.
I've never had shaved tires before. Any tips?
Old Sep 29, 2006 | 07:40 AM
gnhovis's Avatar
gnhovis
Reverse
I ran these tires at Summit Point last weekend for a CCA DE and they worked great! I felt I had a very high level of grip (even on a misty track) and when they started to give, they gave-way very predictably. Even with my stock-lack-of -camber I had pretty even tire wear all around.
Here's a little video. (Keep in mind this is only my 3rd DE...)
Old Sep 29, 2006 | 07:58 AM
PGT's Avatar
PGT
I'm looking at 215 or 225 RS2's for my new 16" set. JCW suspension. Good to know they'll work.
Old Sep 30, 2006 | 11:03 AM
84im's Avatar
84im
When compared to a 195/55-16 the 225/45-16 has a .4 inch smaller diameter (1.9%). 215/45-16 diameter is 3.4% smaller than stock.
Old Oct 12, 2006 | 06:10 PM
jsf252's Avatar
jsf252
Tire size?
Hello all,
This is my first "Official" post. I recently bought my first 03 MCS with the 16" X-lite wheels. Coming from a BMW-only background I am blown away by this car. All of my friends (most of which own American V8's) get out of the car with an ear-to-ear grin!
Anyhow, these are my wheels:
http://www.realoem.com/bmw/showparts...07&hg=36&fg=15
I've spent the last hour poring over post after post for the best tire size for these wheels. I dont need the largest tire, but I want the most rubber without rubbing problems. I've owned 4 E30's and currently have an E36 328is and I've ran Yoko's on all of them. The E36 currently has AVSES100's on it. I drive this MINI pretty much daily so I need something like that tire or harder (no AVS sports or Advan A048's... LOL).
So whats the largest tire width I can get away with on the 16's? 205? 215?
Any and all info is GREATLY appreciated!
Josh F.
Old Oct 12, 2006 | 08:02 PM
90STX's Avatar
90STX
Should be okay with 225/45-16 Hankook Z212. For sure okay with 215/45-16 Hankooks or the same size Falken Azenis 615.
Both of the above are great summer tires which are far more streetable than A048s.
Scott
90SM
Old Oct 13, 2006 | 07:32 AM
jsf252's Avatar
jsf252
Scott,
Thanks for the reply it's much appreciated.
So do most people run 225's on their Mini's? I have 225's on my E36 even thought the spacing on the rims are different I might be able to slide one of those tires under the fender just to see. Dont want to cut anything and I REALLY dont want any rubbing when I turn tightly. I trust your judgement, but I would like to hear from more people, especially those running 225's with stock suspension and stock wheels.
Thanks again!
Josh
Old Oct 13, 2006 | 02:18 PM
scobib's Avatar
scobib
I ran 225/50R15's on stock-size wheels with no issues - and my car is lowered 1.2".
Hankooks seem to run narrower for whatever reason - e.g. in the 225/50R15 size, the z212 is the same width or slightly narrower than the 205/50R15 RT-615 Azenis.
oeklm
Feb 17, 2016 01:00 PM
yukinoinu
Sep 20, 2015 09:10 PM
gowest
SCCA Solo and ProSolo
Nov 21, 2005 06:57 PM
dpayne1
Suspension
Jan 9, 2003 07:32 PM
