question about tires
Old Sep 6, 2006 | 04:22 PM
TEDDYGP's Avatar
TEDDYGP
hi i have a question ,i just order a set of volk racing ce28n 17x7.5 +43 offset and i want to know can i use 215/45/17 tires (my cars is lower) ,because my freind tell me it will rub so is that true.thanks
Old Sep 6, 2006 | 04:56 PM
Passat774's Avatar
Passat774
How much did you lower your car?
Old Sep 6, 2006 | 05:33 PM
TEDDYGP's Avatar
TEDDYGP
I Have The Jcw Sport Suspension Kit[size=3] .[/size]
Old Sep 6, 2006 | 07:01 PM
Passat774's Avatar
Passat774
IMO, you should be fine.. It may rub under a full load if you car is full of people and stuff..
Old Sep 7, 2006 | 04:15 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Generally if you don't lower you MINI that much then it should fit OK.
If you get slight rubbing it will be on the inner upper outer edges of the plastic inner wheel well on the rear tires. Some plastic and some rubber on your tires will wear off. If the tires are worn then there is likely to be less rubbing. When you put four people in your MINI the suspension is compressed and this increases the chance for rubbing especially over bumpy uneven roads.
Another adjustment you can make is to make the rear negative camber a little more negative so that the tire edge clears the wheel well. Any negative camber from -1.8 to -1.0 degree is fine for the rear.
Old Sep 7, 2006 | 07:44 PM
onasled's Avatar
onasled
The rears will rub on cornering and bumps. You will most likely need to do some trimming
Old Sep 7, 2006 | 09:33 PM
TEDDYGP's Avatar
TEDDYGP
thanks for help
Old Sep 8, 2006 | 05:01 AM
kenchan's Avatar
kenchan
those are nice wheels.
W0TM8
Dec 19, 2019 07:50 AM
Mini'mon
Aug 16, 2015 04:15 PM
Mini'mon
Aug 16, 2015 12:47 PM
Emnotek
Aug 13, 2015 05:47 PM
jrezzo
Aug 9, 2015 10:32 PM
