Suspension Koni FSD's with or without rear sway bar mod?
Old Aug 30, 2006 | 08:24 PM
CINIMIN's Avatar
CINIMIN
I have seen lots of comments on FSD's with various springs but nothing on FSD's with different rear sway bar setups. Has anyone done FSD's with a 19 rear bar with stock springs? Any experiences with other combinations?
Thanks in advance for any comments.
Old Aug 30, 2006 | 08:26 PM
mini552's Avatar
mini552
I have an '06 Cooper (MC not MCS) with the standard sport suspension, and will probably do the FSD/Hsport combo in the next week. I already have the Hsport 19mm rear sway bar. PM me and I'll let you know how it works out - the 19mm rear bar should simply help reduce understeer and shouldn't impact the effect of the FSDs - i.e. should simply help the overall handling effect.
Old Aug 30, 2006 | 10:07 PM
markldriskill's Avatar
markldriskill
I did FSD with Alta 19mm rr sway installed at the "more stiff" setting. I'm VERY happy with this combination. I kept the stock S "sport" springs, which are linear rate, rather than progressive (most if not all of the lowering springs are progressive) and therefore are a bit more "predictable" during cornering. I was also hesitant to lower due to Koni's cautions against doing so with the FSD. However, I too have read several posts saying they did mild lowering and have not had any problems.
The changes I noticed:
smoother and quieter ride
much more pleasant on long trips and daily commute
turns in better (a bit less understeer)
VERY little body roll
I think the 22mm might have been too much for me, but I've often wondered anyway whether I might like one. I'm too cheap to just buy one to try it out, though.
MOtor on
Old Aug 30, 2006 | 10:24 PM
Dr Obnxs's Avatar
Dr Obnxs
The two functions
are somewhat separate functions.... Shouldn't matter, and I think cars with FSDs still exhibit understeer.
Matt
Old Aug 31, 2006 | 02:36 PM
Crashton's Avatar
Crashton
FSD's are on my wish list. I have a H-Sport rear sway bar & highly recommend one to every MINI owner who wants a better handling car. It's a high bang for the buck mod.
W0TM8
Dec 19, 2019 07:50 AM
pre shrunk
Aug 18, 2015 11:09 AM
Bennyboy
Aug 18, 2015 07:28 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
