Suspension 2 Questions - M7 Springs and Tire Size
Old Aug 30, 2006 | 03:27 PM
SoCar S's Avatar
SoCar S
Is anyone running M7 springs with R90's with 215/45/17 tires (- That tire size can fit the R90 right?) ?
Any rub?
Thanks in advance.
Old Aug 30, 2006 | 07:26 PM
Partsman's Avatar
Partsman
Legion_of_Doom
I'm running R98 Webspokes, two piece wheel like the R90, same offset, same width, with 215/45/17 tires and M7 springs. No rubbing. I also don't load my car up either. I also have wheel spacers on that I made, doesn't rub on the lip either.
Old Aug 31, 2006 | 07:27 AM
FUEGO's Avatar
FUEGO
What is the offset of the R90/R98 wheels? When my runflats are toast I'll be looking at a lighter 17" wheel and wider tires - prolly 215/45s.
Old Aug 31, 2006 | 08:06 AM
Partsman's Avatar
Partsman
Legion_of_Doom
http://www.mini2.com/forum/faq.php?f...factory_wheels
The factory 17s are not very light.
Old Aug 31, 2006 | 09:14 AM
FUEGO's Avatar
FUEGO
I'll be going aftermarket for the wheels, but the question was intended to help me figure out what offset would work for the wider tires. Thanks for the reference link!
Old Aug 31, 2006 | 09:49 AM
meb's Avatar
meb
Find a wheel that is light - relatively - one that offers a bit more back space - wider to the inside while also have a better offset for handling. something in the 7.5" width range and a 38-40mm offset - 38 is better.
Old Aug 31, 2006 | 10:54 AM
FUEGO's Avatar
FUEGO
Thanks Meb. I've been really happy with Rotas for my AX wheels and have also been looking at some of the Fliks, and the TD Pro Race 1.2 and 2's. I still have a few miles left on the RFs before I need to decide. Other considerations include fitting over a Wilwood 16" kit and eventual replacement of the M7 springs with custom Leda coilovers. Lots of homework to do....
Old Aug 31, 2006 | 03:44 PM
cooldaddy's Avatar
cooldaddy
guess I picked me some good wheels but this will cause rubbing if used with M7 springs and 215/45 tires - I had to do some serious dremeling for the rear wheels to stop rubbing on even the smallest dip/bump...
kazyn
Oct 25, 2019 02:34 PM
Mini'mon
Aug 16, 2015 12:47 PM
Edgar78
Aug 15, 2015 05:33 AM
Emnotek
Aug 13, 2015 05:47 PM
