Detailers Paradise introduces 2 new products in the Prima line: Epic & Amigo
Detailers Paradise is proud to introduce two new members of the Prima line: Prima Epic, a synthetic wax & Prima Amigo, a polymer-based pre-wax glaze.
Here are summaries of each product...
Prima Epic is the most highly-anticipated addition to the Prima product family. It is a long-lasting synthetic wax with a brilliant wet-look shine. The combination of resins and polymers creates a barrier which protects against UV and environmental damage. Epic is particularly resistant to mag-chloride, the damaging ice-melt chemical used in many snowy parts of the country. The super-slick finish is extremely dust resistant. Epic is non-dusting as well as extremely easy on, easy off. In addition, Epic is very concentrated- it takes only 1/2 ounce per MINI application!
What exactly is Prima Amigo? It really defies definition and product categorization. As the car companies like to say, “It’s a segment buster.”
Still, what is it?? Amigo is a paintwork cleanser... a polymer-based glaze... AND a super-fine polish which levels up to 3000 grit imperfections. Combine all three properties and you can see why we think it doesn’t fall into any currently defined categories of car care products.
As a paintwork cleanser, the mild cleaners in Amigo break up oxidation and remove dead paint. Embedded grime is gently lifted from the surface. Mineral deposits from water spots disappear. In this way, it is the perfect prep-step for well-cared-for paint that just needs a cleaning before wax.
As a polymer-based glaze, it fills slight imperfections, adds stunning gloss, while leaving the finish slick to the touch. What's unique about Amigo as a glaze is that it is polymer-based. Although it doesn’t provide protection the way Prima Epic will, it does allow you to go directly to your wax step without any bonding or durability issues. Try that with a “normal” glaze and your protection will simply rinse off. Prima Amigo allows you to fill imperfections, add gloss, then seal it in with your synthetic wax. No other product on the market gives you what Prima Amigo gives you.
Amigo is especially effective on black and red paint. Have you ever fought with your black or red paint as you tried to remove the very last bit of hazing left by your polish steps? With Amigo, Black becomes a crystal lagoon of depth and clarity. Red becomes a bright liquidy glow of its former self. Even light colors pop with brilliance. Prima Amigo is your last step to perfection.
Whether you are cleaning, glazing or polishing, spend some time with Amigo and you will see why we think it will be your new best friend.
Prima is an exclusive line of car care products custom formulated by Detailers Paradise. The formulas are uniquely ours. Great lengths were taken, and no expense spared, in order to create a family of products second to none. Give Prima a try... we guarantee you'll love it!
Please let me know if you have any questions about Epic or Amigo, or any of our other products and tools. We're here to help!
-Heather
-Heather
patsum
26
May 29, 2021 06:29 PM
OutMotoring
Sep 8, 2015 06:27 AM
Sep 4, 2015 11:43 AM
