R50/53 anti freeze leaking
Old Aug 29, 2006 | 06:18 AM
musumekiller's Avatar
musumekiller
anti freeze leaking
Anyone run into my problem before? I think I saw some anti freeze under my car. However, it doesn't happen everytime. When I chk my anit freeze level, is almost minimum.
Old Aug 29, 2006 | 08:12 AM
Yucca Patrol's Avatar
Yucca Patrol
Look just below the coolant expansion tank to see if there is any dried salty looking deposits on the heat shield. If so, your expansion tank is leaking. Early models had problems with the tanks cracking at the seam in the middle of the tank.
Also, your air conditioner will leak water from condensation on the coils. That is normal, and is most likely what you have seen.
In a pinch, you can top up your coolant tank with distilled water if you don't want to mess with mixing up a little bit of coolant.
Old Aug 29, 2006 | 08:15 AM
JoeCool's Avatar
JoeCool
Perhaps this goes without saying, but I'll say it anyway. That expansion tank is under pressure during or after a drive, so if you're going to pop the cap for any reason, do so with a COLD engine!
Old Aug 30, 2006 | 08:46 PM
xizor's Avatar
xizor
are you sure its not condensation from your compressor, stupid question, but more likely if you see fluid coming out from under your car
ian260
Mar 29, 2017 06:08 AM
gar56
Nov 15, 2016 06:41 AM
bahman
Feb 14, 2016 10:29 AM
gnhovis
Dec 14, 2015 05:31 PM
Oct 1, 2015 12:13 PM
