Suspension H&R swaybars @ TireRack!
Old Apr 2, 2003 | 11:29 AM
Alex@tirerack's Avatar
Alex@tirerack
H&R swaybars
Alex
Old Apr 2, 2003 | 11:31 AM
dave's Avatar
dave
pug poo picker-upper
Are these intended to be used as a front and rear combination?
Old Apr 2, 2003 | 11:41 AM
Alex@tirerack
I belive that is H&R's intention. They can be purchased seperatly though.
Alex
Old Apr 2, 2003 | 04:43 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Do you have any pics of the rear and dimensions yet? The diameter, whether they are hollow, and if they are either the modulus of the material or the effective rate would be great!
Thanks,
Randy
Old Apr 2, 2003 | 04:50 PM
Alex@tirerack
>>Thanks,
>>Randy
I will post pics when we have them. I will do reseach on the rates for you.
Alex
Old Apr 2, 2003 | 11:09 PM
bbt4's Avatar
bbt4
randy,
generally do we want a higher or lower modulus (E) as swaybar material. i know that the higher the value of E goes, the more brittle the material, and vise versa for more ductile materials. how are swaybars designed?
bbt4
Old Apr 18, 2003 | 09:26 AM
Alex@tirerack
$220 front
$169 rear
in stock!
I have been waiting to hear back on modulus and rates on these bars
Alex
Old Apr 18, 2003 | 12:24 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
It looks as if the rate is 18mm for the rear. Even with going to a 19mm rear and a 27mm front, you are basically back to stock as far as understeer goes, only flatter. I really wonder why they aren't going stiffer in the rear? I have found that without any camber adjustment in the front to go more negative, you need a larger rear bar and no front bar. Keep us posted on the modulus! Thanks for the info Alex.
Randy
Old Apr 27, 2003 | 12:48 PM
Mbanks21's Avatar
Mbanks21
$400 for sways? I got my Eibach sways for closer to $350, 25mm front and 19mm rear, million mile warranty.
Old Apr 30, 2003 | 04:18 PM
Alex@tirerack
I am sorry that it has taken so long to reply.
To answer your question about H&R's sway bar material, they use ‘inductively’ treated 55CrV4 alloy. This inductive treatment hardens the material from the inside out, giving much more resilience and toughness than other alloys.
The figures for this material are as follows:
Tensile Strength 1150 – 1300N/Mmm^2 (Mpa)
Modulus of Elasticity (E-Module) 210000N/mm^2 (Mpa)
You may say that stiffness can be duplicated using a different diameter bar, but that does not mean that the quality is equal. Because H&R steel is a spring material – hence it’s inherent resilience, it is very difficult to bend, and maintain, specific dimensions.
Of course H&R will never cut corners, so they invested in a CNC bending machine specifically for this material. After the material is bent, the ends are ‘forged’, and the bar is powder coated.
H&R sway bars feature maintenance free Teflon lined polyurethane bushings are included with every kit, giving uncompromised street performance.
Concerning the MINI specifically, we have released a 18mm rear bar first. H&R's engineers in Germany did extensive testing and development on these cars and found that the adjustable 18mm bar gave the best balance and drivability.
Realizing that what may work perfectly on the Nurburgring may not be perfect at Road America, H&R will be releasing a North American specific, 19mm rear sway bar in the coming months.
I'll keep you updated
Alex
_________________
Alex ext 294
800 522 8473
Tire & Wheel forum moderator
www.tirerack.com
alex@tirerack.com
Old May 1, 2003 | 12:31 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Great info Alex! Thanks!
Is the bar tubular or solid?
Randy
Old May 1, 2003 | 01:34 PM
Alex@tirerack
Randy
they are Solid.
Alex
>>Randy
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
gar56
Nov 15, 2016 06:41 AM
Suspension Products
Oct 1, 2015 11:53 AM
gnhovis
Sep 28, 2015 10:56 AM
gnhovis
Sep 28, 2015 06:28 AM
