R50/53 Any trunk release other than key and from outside???
Old Aug 20, 2006 | 01:55 PM
No MCS Yet's Avatar
No MCS Yet
I had a problem the other day which made me think that if there's no other way to get into the trunk, then MINI might have screwed up.
Here's the story: I was driving down Las Olas Blvd last night when all of a sudden my car just died. I don't mean it turned off, it died completely to where the hazards wouldn't even turn on. I had no clue what it was. I had been rear ended two weeks ago and I just got the car fixed. I also had them install a Borla Exhaust, so I thought it might have been the exhaust installation. I wanted to get to the battery, but guess what, since the car was dead, I couldn't even open the trunk. Unless there's a latch on the inside, then there is no hope. No electronics where working.
So I had to climb in from the front, lift open the shelf in the back, and pull down the back seats. Then while sitting in the back seat, I had to open up the floor to check on the battery. I moved the ground wire a little bit, and all the lights came back on. So this must mean that the ground wire was loose, but it didn't seem that loose. I tried to tighten it up today, but I didn't have that much luck, just a little more secure.
Any ideas or thoughts?
Old Aug 20, 2006 | 02:00 PM
Minirox's Avatar
Minirox
There is a cable under the back seat manual release for the boot. Depending on year it is on the pass side or middle.
Crashton's Avatar
Crashton
There is an emergency release under the back seat. It's in the owners manual.
Old Aug 20, 2006 | 02:21 PM
lotsie's Avatar
lotsie
If a battery cable is a little bit loose, it's to loose, period.
Use the proper size wrench on it and all should be fine.
Mark
Old Aug 20, 2006 | 06:09 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
My 2003 doesn't have the release cable under the rear seats...
The only time my trunk was not working, I had important papers I needed in the trunk, so I had to squeeze my arm between the rear seat and the cover, and grab one of the release handles to get my papers back...
Old Aug 20, 2006 | 08:11 PM
No MCS Yet's Avatar
No MCS Yet
Thanks for the replies. I really appreciate it.
OutMotoring
Mar 3, 2017 06:29 AM
gnhovis
Dec 14, 2015 05:31 PM
FatherG
Sep 29, 2015 02:47 PM
jennster
Sep 28, 2015 06:19 PM
BMC_Kid
Sep 27, 2015 04:31 PM
