R50/53 Should my right xenon headlight point higher?
Old Aug 18, 2006 | 02:50 AM
T2Nav's Avatar
T2Nav
Good morning,
I got my rocket-car about three weeks ago, and noticed that the right xenon headlight (the blue low-beam) points slightly higher than the left. Not sure if I need an adjustment, or if this is intentional so I can see as far as possible without blinding oncoming drivers. Whad'ya think?
Old Aug 18, 2006 | 04:01 AM
o4amini's Avatar
o4amini
What laugh I had over your sig. I have the Xenons and they level up as soon as I turn them on. I hope someone here can help.
Old Aug 18, 2006 | 04:13 AM
jdmarino's Avatar
jdmarino
I have read this on these forums
Originally Posted by T2Nav
...is [this] intentional so I can see as far as possible without blinding oncoming drivers?
Yes. At least I have read this before on NAM.
Old Aug 18, 2006 | 04:25 AM
jonnieoh's Avatar
jonnieoh
I've noticed that the light pattern from mine is lower right about where oncoming cars would be. I think this is indeed intentional, as a safety feature for oncoming cars. The right is taller, because it will never be shining into the eyes on oncoming motorists.
Old Aug 18, 2006 | 05:27 AM
mr_edly's Avatar
mr_edly
My '05, delivered in Oct '04, had both the Xenons pointing too low, leaving me with outstandingly lit pavement up to 30-ft in front of me. And others have had the same problem -- see threads below.
Dealer wouldn't do anything about mine.
I used the standard mark-against-a-wall, back off on flat ground, and mark the light pattern, adjust. See the 2nd thread below. I can't find the thread that had the photos, but if you keep track of how the pattern changes, you can figure out which direction to turn the screws. Don't give up quickly looking for the adjusting screws -- they're not quick and easy to find. Adjust with power off so you don't fry yourself -- there's high voltage in there.
I tweaked mine up, can see much farther, haven't got anybody flashing me as if I had my brights on.
https://www.northamericanmotoring.co...=aiming+xenons
http://www.mini2.com/forum/faults-fi...t=xenon+adjust
http://www.mini2.com/forum/mini-coop...t=xenon+adjust
https://www.northamericanmotoring.co...ight=aim+xenon
Old Aug 18, 2006 | 06:04 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
The right xenon should be a little higher than the left one... It has something to do with road signs...
At least, it is a law in Canada...
Old Aug 18, 2006 | 06:14 AM
Chimera's Avatar
Chimera
Not just Xenons either, my right standard headlight is slightly higher than the left...I just figured it was normal, makes sense.
Old Aug 18, 2006 | 06:54 AM
G. P. Burdell's Avatar
G. P. Burdell
The "uptick" in the beam pattern is there to light up road signs, but the left and right headlamps' horizontal cutoffs should be even with one another.
Daniel Stern has a good set of aiming instructions on his Web site:
http://www.danielsternlighting.com/tech/aim/aim.html
Old Aug 18, 2006 | 01:05 PM
lotsie's Avatar
lotsie
The right xenon should be higher, for reading road signs, and seeing further up the side of the road.
I had my dealer adjust mine slightly higher than the factory setting, and have had no problems with being flashed by oncoming traffic.
Mark
molala
Oct 2, 2015 01:53 PM
Sep 4, 2015 02:34 PM
Sep 3, 2015 10:29 AM
Suspension Products
Sep 3, 2015 09:41 AM
