Cooper (non S) Modifications specific to the MINI Cooper (R50).
New Exhaust Installation...
Old Aug 5, 2006 | 04:18 PM
Difference_Engine's Avatar
Difference_Engine
Hey Fellow Motorers!
I just picked up a new OEM MINI cooper (non-s) sports exhaust from a fellow NAMer. On the oustide it's shapped exactly the same as the standard exhaust. I have three questions.
1. Is installing this a DIY project? I have jacks, car tools and a reasonable amount of mechanical ability (I've installed the s-gas cap conversion, can change wheels for season, oil & filter changes, and I'm confident I could do a rear swaybar install).
2. If it's not a DIY: Should I get it done at a standard muffler shop or goto the local BMW dealership (my closest MINI dealership is a 70 miles away).
3. How long would this take at a professional labor rate?
Thanks in advance!
Old Aug 5, 2006 | 05:18 PM
UKCoopeR's Avatar
UKCoopeR
if you can handle a rear sway this is most def a diy
the only thing to look out for it the bolts between the resonator and the cat can be a pain as they get VERY stiff apply WD40 liberalry, do you have a copy of the instructions?
it is a straight forward bolt-on 10 bolts in total i think
...unless this is a kind that requires cutting the oem one, but i dont think it is
Old Aug 6, 2006 | 07:24 AM
asodestrom's Avatar
asodestrom
It's a fairly easy job. Make sure your exhaust is cold. That will help get the bolts out. Also make sure you check for leaks when you are done.
Good luck.
Old Aug 21, 2006 | 09:07 AM
joetc's Avatar
joetc
I think you might need the Hanger Removal last time when I with out the hanger removal Eventhose i used WD40 took me like over hours but if you W/O that still can off just take longer time and harder
patsum
26
May 29, 2021 06:29 PM
shorenetworks
Nov 4, 2019 06:18 PM
embiggenedmini
Oct 15, 2015 12:36 PM
buckeye_hunter
Sep 2, 2015 01:24 PM
Sep 2, 2015 09:05 AM
