Interior/Exterior Lambo Door Conversion
Old Jul 30, 2006 | 09:00 PM
MINICHEF's Avatar
MINICHEF
CHECK THIS ONE OUT. $14.95 FOR A LAMBO DOOR KIT.
http://cgi.ebay.com/ebaymotors/MINI-...QQcmdZViewItem
Old Jul 30, 2006 | 09:24 PM
not-so-rednwhitecooper
lol its an instruction manual
Old Jul 30, 2006 | 09:44 PM
polizei's Avatar
polizei
Yea, I saw that too. It's just a manual. Dang, because I was thinking of getting that too....
-Cody
Old Jul 30, 2006 | 10:57 PM
Rick-Anderson's Avatar
Rick-Anderson
I hope you guys are joking because there couldn't be anything worse.
Old Jul 30, 2006 | 11:02 PM
MiniChik's Avatar
MiniChik
Well if anyone is really serious, here ya go: LSD Doors
Old Jul 30, 2006 | 11:19 PM
Rick-Anderson
Don't forget the wheels. Bling bling.
Old Jul 31, 2006 | 06:55 AM
ImagoX's Avatar
ImagoX
I actually always liked this MOD because it's 100% invisible until you actually open the door... Then it's like "Wow!" from everyone around. thanks for the link- the tech behind it is actually kind of interesting I think. Of course, I can never do this on a cabrio, but I'd actually consider it on a tin top. Does anyone know if such a mod affects the sealing ofthe door or windows? As cool as it is, I wouldn't do it if it affects the integrity of the seals.
EDIT:
Oh, you CAN do it on a cabrio!
http://www.shopatron.com/product/pro...50020007/431.0
I wonder how it works when the top is closed? That roof overhangs the window glass...
Old Jul 31, 2006 | 07:08 AM
mdsbrain's Avatar
mdsbrain
I emailed this company to see if their kit is any different then other kits for the MINI. Other company lambo door kits require you to relocate the windsheilf washer bottles. I didn't want to go this extreme. I'd love for a bolt-on kit with a wire harness addition and go :-)
Old Jul 31, 2006 | 07:09 AM
irieman's Avatar
irieman
How about... hot-metallic orange!*
actually, i must say "bondgroup" has some pretty nice cars, in a japanese bling-overkill sort of way!
http://www.auto-g.jp/special/2004_0628/index02.html
Old Jul 31, 2006 | 07:16 AM
ImagoX's Avatar
ImagoX
According to other things I'm seeing on the LSD door hinges, they apparantly mount right into your existing door bolt holes, and require no cutting, welding or anything else. They work by first opening out like a standard door and THEN pivoting upwards afterwards. That explains how they'd work on a cabrio. They're certified to be as safe as the original door mounting by the German government (or so the manufacturer claims).
I have to admit, I'm hellishly intrigued, as the install seems dead simple and seems to have no negatives - it even looks reversible if you go to sell the car later and the buyer doesn't want the vertical doors (although why they wouldn't is a mystery - this is really cool). The only thing that worries me is that, when open, it sort of looks like the door is half blocked. In that shot above, for example, does anyone know if that's fully open? If so, it's somewhat in the door opening, isn't it?
Old Jul 31, 2006 | 07:30 AM
mdsbrain's Avatar
mdsbrain
Install instructions:
http://www.lsd-doors.de/content/50_D...sd50020007.pdf
Old Jul 31, 2006 | 08:04 AM
qwertmonkey's Avatar
qwertmonkey
Thanks mdsbrain!
Old Jul 31, 2006 | 08:11 AM
mmatarella's Avatar
mmatarella
Be aware unlike most other cars, the MINI hinge doesn't unbolt. You have to grind it off the car. So this mod is not easily reversed like on most cars. Also this kit appears to be one where the doors only open about 45 degrees. Actually pretty tough to get in and out. There is at least one MINI kit that the doors open a full 90-100 degrees. I don't recall which but it'd be a easy NAM search on lambo.
The kit I'm thinking of even allows just swinging the doors normally all the way too.
Old Jul 31, 2006 | 08:19 AM
ImagoX's Avatar
ImagoX
Intreresting info... If anyone finds a link to an alternative solution that swings the doors further away for the car, I'd love to see it. I believe that the LSD hinges may allow for full hgorizontal opening as well - their site talks briefly about the hinges allowing for "dual functionality", but I'm not sure if that refers to the "out then up" nature of the hinge or if it's truly either/or.
EDIT - Wow... you actually have to cut away a significant portion of the fender as part of this as well... So much for "simple installation". This is certainly NOT reversable. Thanks for posting those instructions!
Old Jul 31, 2006 | 11:15 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
That's the color I want my car to be. With a black roof/grille/scoop/boot handle.
Old Jul 31, 2006 | 02:07 PM
ylwjkt's Avatar
ylwjkt
It is correct that the hinges need to be cut off, and probably the fenders
will need to be rolled. That is why you must relocate your washer bottle.
It is important that you get a quality kit, as I have seen a lambo door
ripped off it's hinge in the wind because of the cheap universal kit that was
on it. This looks like a pretty good kit: http://www.lsddoors.com/
Old Jul 31, 2006 | 03:08 PM
MiniChik's Avatar
MiniChik
Of those kind of kits LSD is probably the best. They've even safety tested them. The doors swing out and then up but you do loose about a quarter of the outward swing. They use a gas cartridge so that has to be replaced every couple years. Also LSD is owned by the people who also own, KW, ST Suspensions and Belltech.
Filmy
15
Jun 6, 2023 06:27 AM
jeri534
Nov 6, 2015 01:40 PM
krohm
Sep 28, 2015 12:16 PM
whowantstorace
Sep 27, 2015 06:16 PM
tylewis
Sep 6, 2015 07:36 PM
