Interior/Exterior Speaker replacement:Need advice/help
Old Jul 28, 2006 | 05:51 PM
ekim's Avatar
ekim
Hi,
I've replaced the stock speakers of my S with some Polk's. They all sound pretty good but the front speakers are operating at nearly 1/2 the volume of the rear 6x9's. When I replaced the component speakers there were 4 leads running a full signal (one to each tweeter and 6 1/2" speaker) with two having a high pass filter at the connector for the tweeters up by the handle. Since I only needed one lead per side to feed the crossover of the polks, I took them from the lead to the 6 1/2" speakers. I'm getting a full range sound but the volume is about 1/2 of what the rears are. It can be adjusted with the fader control but that doesn't actually fix the situation.
Any thoughts?
Regards,
Mike
Old Jul 29, 2006 | 06:30 AM
cristo's Avatar
cristo
Alliance Member
Which Polks do you have?
The DB6500's have a sensitivity of 92 db/W, close to the efficiency of the
rear speakers, while the MMC6500's and the SR6500's are 90 db/W, which
is about 63% as efficient as the DB's.
Old Jul 29, 2006 | 10:18 AM
ekim's Avatar
ekim
Curious..I have momo mmc690 polk 6x9's in back and the db650 polks in front.... you may have something there, I need to check the specs....
Old Jul 29, 2006 | 11:12 AM
cristo's Avatar
cristo
Alliance Member
The mmc690's have a sensitivity of 91, the DB690's are 93.
You'd think the DB6500's (92) and the MMC690's (93) would be pretty evenly
matched in terms of efficiency/loudness.
Not sure why they're not. Make sure the fronts are in phase with the rears,
and double check the wiring. Maybe the acoustics of the car interior plays
a role as well.
Old Jul 29, 2006 | 02:48 PM
ekim's Avatar
ekim
Phase of the speakers should be ok as I checked that as I wired them up....the acoustics of the compartment I don't believe to be an issue...still baffled...I heard some h/k speakers, not the whole system, in a mini and was very impressed with sound quality, presence, bass and volume....
Filmy
15
Jun 6, 2023 06:27 AM
RobbyD
Jan 29, 2019 01:22 PM
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
patsum
Oct 1, 2015 06:33 AM
