Suspension Expiramenting with stock springs
Old Jul 5, 2006 | 04:44 PM
qwertmonkey's Avatar
qwertmonkey
Right now, I have the alta pro performance springs. I was thinking about doing a little expiramenting and cutting off 1 coil from my stock ones. Good idea? Bad idea? I am looking for more of a drop instead of performance.
Thank you.
Old Jul 5, 2006 | 04:54 PM
Eric_Rowland's Avatar
Eric_Rowland
Well, if the only cost is your time, and you want to experiment, what the hey. Stock springs are cheap/free if you want to go back to stock.
Realize that by cutting a coil you WILL be increasing the spring rate. I'm sure an engineer could calculate the change.
If you want a dropped car with a comfortable ride, you'll likely be searching in vain. We just don't have that much travel that you can drop it and maintain stock type spring rate.
Old Jul 5, 2006 | 05:49 PM
kenchan's Avatar
kenchan
yeh, i think you'll bounce around a little... but if you get
aftermarket shocks im sure they'll work alright.
the front springs don't have too many coils so might be a pain
to get them in shape to fit the mounts.
Old Jul 5, 2006 | 07:19 PM
onasled's Avatar
onasled
..... drive safely...
Old Jul 5, 2006 | 07:22 PM
qwertmonkey
What could go wrong?
Old Jul 5, 2006 | 08:54 PM
onasled's Avatar
onasled
You are taking an engineered part and in a very non engineering way, altering it. Minis are quite sensitive to suspension and tire adjustments. I'm just a little nervous for you that if you do this and then drive that car in a very spirited manner that the car could rebel and decide to go into a spin. This has happened with people who put different tires on the front then the back.
It may not happen, but just be careful.
Kimolaoha
Dec 5, 2020 09:32 PM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Mini7
Feb 2, 2016 07:52 PM
ltjpunk7
Sep 6, 2015 07:32 AM
Emnotek
Aug 13, 2015 05:47 PM
