R50/53 transmissions blown
Originally Posted by takingcurves
just curious to see who else has blown there trannies
o4 mini cooper s blown tranny at 25,000
I know of one MINI owner that had two lightened flywheels fail, each resulting in a "blown" transmission - but in his case it was the transmission casing that got holes blown in it, rendering the transmission useless.
Originally Posted by caminifan
Out of curiousity, what constitutes a blown transmission? Gears shredded? Bearing(s) failure? Or????
well at first habberstadt told me the throw out bearing and clutch plate shattered ...then later that day also the flywheel was found to be torn up then the next day i was told the whole gear box was trashed ....2nd gear split open and locked and jammed all of it up. and the gears actually blew open the housing
I don't know, but it seems to me that a tranny would make an awful lot of warning noises before it would ever blow parts out of the housing.
Go figure??
Sorry about your gearbox.
Go figure??Sorry about your gearbox.
Go figure??
NOPE NO WARNING NOISES JUST A CLUNK THEN A WHOLE LOT OF CLUNKS AND GRINDS ....MAIN CAUSE IS BELIEVED TO BE THE STOCK FLYWHEEL.... SOMETHING ABOUT CHATTERING? WHATEVER THAT IS
The friction material is on the clutch plate not the flywheel. The flywheel is just a large chunk of steel that bolts to the crankshaft. The belhousing on most cars, ours included does practical zero as far as protection from exploded flywheels goes. All it is made from is cast aluminum. Chattering can be caused by a burned clutch disc & or a burned flywheel. There can also be heat checking of the flywheel caused by excessive slipping & burning of the clutch. It's possible that's where the flywheel came apart. Not a common failure, that God.
You are very lucky to still have both of your feet intact. Flywheel explosions can kill & maim.
The friction material is on the clutch plate not the flywheel. The flywheel is just a large chunk of steel that bolts to the crankshaft. The belhousing on most cars, ours included does practical zero as far as protection from exploded flywheels goes. [Emphasis added.] All it is made from is cast aluminum. Chattering can be caused by a burned clutch disc & or a burned flywheel. There can also be heat checking of the flywheel caused by excessive slipping & burning of the clutch. It's possible that's where the flywheel came apart. Not a common failure, that God.
Originally Posted by kenchan
im sure problems can occur, but this sounds like a very isolated case.
I've never even heard of that, a defect in the flywheel causing such a massive failure? If it was a serious enough defect to cause that kind of "explosion," why did it take 25k mi. to become apparent? Just plain old metal fatigue or what?
I'd love to know how you were driving the car up till then... barring a pretty serious manufacturing defect (very rare with the automated manufacturing checks that are in place), it's HARD to blow out a transmission like that. I helped build drag cycles for a few years and I can count on one hand the number of cracked casings I've seen, even after a disasterous mis-shift....
Originally Posted by ImagoX
I'd love to know how you were driving the car up till then... barring a pretty serious manufacturing defect ...
I blew a hole in my transmission casing. However I don't think it was caused by too much stress from Horsepower but it was wheel hop.
My transmission held up to 10 plus red line launches with drag slicks fine. And then I went to the strip on street tires, wheel hoped like crazy off the line, and pop. Felt like it came out of gear.
I think everyone at the track hated me because I don't think anyone got to run after that. I guess a few quarts of redline tranny fluid will do that...
I was running a spec flywheel and stage three clutch. They are still intact.
Well I don't consider it beating the crap out of it. To me it is pushing the limits. Sure stuff breaks but as long as you figure out to prevent breaking it again. Well to me that is worth it.
Please accept my apologies. I didn't mean to judge you. Your car your business what you do with it.
post #14
https://www.northamericanmotoring.co...ad.php?t=72478
Well, if you drive on the edge then you have to expect that, every once in a while, things are going to slip past it. Personally, I can't imagine driving my car hard enough in any non-track situation to cause enough hop to blow things out like you describe, but it IS your car, that's a good point.
I just hope that you were someplace that bystanders couldn't get caught in ther middle of anything. Sure, I drive faster than the posted limits occasionally, take corners fast, etc., but I've seen some illegal street dragging and racing that really stood my hair on end... people hauling *** at 140 down residential streets, etc.
Hope that's not you. If you really want to go fast, and you obviously have the cash to support a Mini habit, then spend a few bucks more, get track certified and go to town in a safe environment. That's all I'm saying.
Your Mini. Your business. But it's everyone's streets.
I am all for staying off the streets and keeping it in a controlled enviroment.
Hey, I feel your pain. Was just informed I have to fork out $2500 for a new clutch and flywheel for a 2003 MINI with less than 40,000 miles on it.
I hate to say it, but I think I'm gonna get rid of the thing after these repairs.
just buy aftermarket clutch and flywheel, it will be cheaper then 2500.
UUC stage 3 and lightweight fly wheel is what i had on mine and i loved it.
Expensive things.
