Suspension H-sport race rear sway bar
Old Jun 14, 2006 | 06:08 PM
Beecher's Avatar
Beecher
hello all, is anyone out there running the new race rear bar? The soft a middle settings are only slightly stiffer than the middle and stiff on the comp bar. Basically, i know im going to run the comp on the middle of the comp, even before i upgrade to their sport front bar (which i will probably run on soft). Just curious mostly if anyone has it and what they think of it. I just doubt that i will ever run it on stiff, which pretty well negates the purpose of buying it, ecpecially since its not hoolow, which is what atracted me to h sport in the first place. thanks
Beecher
Old Jun 15, 2006 | 07:00 AM
lexmcs's Avatar
lexmcs
Even if you dont plan on running it on the stiffest setting it might be worth it to get. Check out the second link below. Oh yea....Search button is your friend
https://www.northamericanmotoring.co...t=h-sport+sway
Old Jun 19, 2006 | 07:40 PM
Beecher's Avatar
Beecher
yeah, i had used the search and read all that stuff already (and the search is how i never had to post on here before, everything i ever needed to know has been discused, except the use of this particular bar), but none of them actually used it, and i was just curious if that extra 10 percent or so in the first two settings made the car too loose, and what was the third setting like if the the front bar was set to stiff for example. None of that stuff was covered, just the fact that it existed. But thanks for trying to help, i do appreciate it
Beecher
Old Jun 20, 2006 | 07:34 AM
lexmcs's Avatar
lexmcs
please ignore my previous post... must have been pre-coffee. i just realized you are talking about the race bar. Sorry about that.
I can give you some insight on running the competition bar. I tried running it on the stiffest setting and the back kept stepping out (without inducing lift off oversteer) So it looks fun when you are going sideways around an off ramp, but i dont really think thats responsible, so i dialed it back to the medium setting. Now the car feels perfect; back of the car is well mannered, unless in induce some lift oversteer. I think you could still get away with running the race bar on the softest setting, but anything more than that on the street might be pushing it. As for the 10% difference... i doubt you would be able to feel a difference. Hope this helps you decide.
Again sorry bout the confusion.
Old Jun 20, 2006 | 12:58 PM
Beecher's Avatar
Beecher
no problem, i kind of figured you hadnt realized i was talking about the actual h-sport race bar, cause alta calls their big one the race, and its about the same as the hs comp. No problems, I think i will just go with the comp bar, i dont think the extra hundred bucks are worth if for the few times (if any) i actually use the stiff one.
by the way, i like you signature, especially the first one (im not a huge fan of blowers, sorry), but in the old days (sounds weird, a 22 year old saying that) they use to destroke and sleve their engines for certain classes of recing to be on the small end of the size range, and beat the pants off the big engines cause they could rev so much faster and higher. This was before they invented drag races tho, and fuel injection, and ecu's...
thanks again,
Beecher
Old Jun 20, 2006 | 02:40 PM
lexmcs's Avatar
lexmcs
Beecher
Easy there old timer!!! lol... i am a big fan of anything fun and fast. hence the MINI and my 86 Honda VFR750 that red lines at around 11500. If i get really bored i take a lil trip down to DC and ride my brother's Ducati M1000SIE or Impreza STI... gotta have options you know.
back to the subject at hand, I am sure you will be happy with the comp bar.
W0TM8
Dec 19, 2019 07:50 AM
Bennyboy
Aug 18, 2015 07:28 AM
OZMDD
Aug 17, 2015 02:53 PM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
