going from 15" to 17" Cooper wheels & Tires
Old Mar 18, 2003 | 05:15 PM
lbc-guy's Avatar
lbc-guy
OK,
I have decided to upgrade my 2002 MINI Cooper and replace the original 15" wheels with the 8 spoke 17" wheels with pirelli run flats. Will it be a straight swap or will I have to get spacers. I have a cooper, not a cooper S.
Old Mar 18, 2003 | 05:28 PM
dukesantos's Avatar
dukesantos
It's a straight swap, but make sure you have read the threads about the 17 in. runflats. First, the runflats and the larger wheels are much heavier, you're going from the mid-30 lbs. to 50 or more per wheel/tire. That extra weight has a noticeable effect on acceleration and braking. Second, the handling in terms of cornering will improve but some people have reported tramlining with the Pirellies on grooved roads. Finally the ride, the runflats have very stiff sidewalls and will not give as comfortable a ride as the regular radials that you now have. Don't get me wrong, I have both types of tires and they each have their plusses and minuses, I just wanted to pass on some observations.
I would suggest looking at some of the light 16 in. wheels that are available and a sporty non-runflat like the Toyo T1-S or Falken Azenis. :smile:
Old Mar 18, 2003 | 05:34 PM
lbc-guy's Avatar
lbc-guy
Thanks for the reply. I will look at those options. Do the 17" wheels work with other types of tires that are not run flats?
Curiousl
Old Mar 18, 2003 | 05:37 PM
Mister_S's Avatar
Mister_S
lbc-guy,
Welcome to MCO! :smile:
They will fit no problem. No spacers needed.
Nobody likes the runflat tires; too heavy, too harsh a ride, eye-popping replacement cost. I'm planning on running the (8-spoke) 17" S-Lite wheels on my S, but will run a standard performance tire. This poses a risk for me in that the S has no spare, but you're lucky; your car has a spare. Do some searching in these forums for runflats and you'll see what people are saying.
You will also read that the 17" S-Lites are heavy compared to aftermarket wheels. This is true, but I can't get past just how "right" the S-Lites look on the MINI. They look soooo good, and the extra 5-10lbs per wheel should translate to better pothole durability.
Classic Auto Campus, an MCO sponsor (see the sponsor directory), has a pretty good price on brand new S-Lite wheels.
Best of luck to you,
James
reverse01134
Jan 16, 2017 06:37 AM
zdw2082
Oct 5, 2015 09:59 AM
Mini'mon
Aug 16, 2015 04:15 PM
nomar116
Aug 9, 2015 09:42 AM
