coolant temp sensor location
Old Jun 2, 2006 | 02:14 PM
scs65's Avatar
scs65
Can someone clue me in as to the location of the water temp sensor for a 2003 Mini? Radiator fan has stopped working. Checked the easy stuff, fuses etc. Hoping for a defective sensor rather than a fan.
Old Jun 2, 2006 | 09:08 PM
MSFIT's Avatar
MSFIT
place to start
Old Jun 3, 2006 | 09:05 AM
scs65's Avatar
scs65
thanks a lot
well, there was certainly a LOT of info there, I think I looked at every diagram and parts list, but still can't find that darned sensor.. I found such a part listed on some other site and saw a picture of it, it looked like it screwed into the engine block, but I can't find it on this Mini...
any other suggestions/ ideas ?
Old Jun 3, 2006 | 10:35 AM
lotus87's Avatar
lotus87
Try the right end of the cylinder head. (I suppose that would be the rear of the cylinder head.)
Old Jun 3, 2006 | 02:02 PM
namwob's Avatar
namwob
Did you check both fuses in the engine bay fuse/relay panel? (FL9 50 amp & FO5 5 amp)
The low speed relay..same panel (F 2nd from front of car) can be switched with the heating & ac blower relay (D 4th from front) The high speed fan relay is unfortunately mounted with the fan.
I gather you tried running the ac which makes the fan run.
Old Jun 3, 2006 | 02:06 PM
cristo's Avatar
cristo
Alliance Member
try this pic instead: (#7 = temp sensor, water)
http://www.realoem.com/bmw/showparts...86&hg=11&fg=15
Kimolaoha
Jul 5, 2023 01:04 PM
Cereall
Sep 5, 2019 06:05 PM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
Chippawaguy
Aug 19, 2015 10:59 AM
tylewis
Aug 18, 2015 06:53 AM
