Interior/Exterior Removing down tubes?
Old Jun 1, 2006 | 10:55 PM
WhiteDogs's Avatar
WhiteDogs
I searched the forum but didn't get any relevant hits. I want to remove the downtubes and can get them lose by removing the 2 screws but there must be more to do. Anyone care to fill me in?
TIA,
\pat
Old Jun 1, 2006 | 11:48 PM
CruiseControl's Avatar
CruiseControl
I'm not too good at this but here's the idea. Pull up and take off the shift ****, remove shift boot and bezel. Might need to remove change cubby, and you will need to remove the aux cup holder. Remove the down tube screws (on the sides) and remove the shifter/cup holders/lighter pod. After that is unscrewed, the tubes should just fall towards the floor as you pull it all out of place. Maybe someone else can clarify any discrepancies.
Good luck
Old Jun 2, 2006 | 12:19 AM
SRLancer's Avatar
SRLancer
Newministuff.com has a really good description with pictures of how to get your downtubes out in the DIY guide for replacing your stereo.
http://www.newministuff.com/new/inde...ion=13&diyid=6
That's the method I used to install my bluetooth kit and it worked like a charm.
Old Jun 2, 2006 | 06:35 AM
usaaus's Avatar
usaaus
Depends on the year of your MINI. Prior to the '05 update you could, with a little flexing, pull them out at the top and lift them out.
With the '05 - '06 revisions to the console, you need to remove the consiole and take them out the bottom (they have a lip on them that precludes them being pulled up.
However, if you are just trying to get to the toggle switch bank or radio, you don't need to remove them. Just take out the two screws each side, pop the lower edge of the front dash fashia out a little and the down tubes can be moved sideways enough at the top to access the radio and switch bank.
Old Jun 2, 2006 | 07:13 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Here's a good thread from my buddy uptick over on nemini.org
http://nemini.org/ForumsPro/viewtopic/t=4017.html
Old Jun 2, 2006 | 07:39 AM
qwertmonkey's Avatar
qwertmonkey
MINI2 has the how to somewhere....
Old Jun 2, 2006 | 07:40 AM
qwertmonkey
Removal of the dash downtubes is required for changing the head unit or installing the toggle switch panel.
Each dash downtube is screwed to the radio-a/c-toggle-switch cluster. The top of each downtube is covered by the dash center fascia [surrounding the speedometer and two air vents], and the bottom of each is anchored in the center console.
To remove them, use the following tools and instructions:
  • Torx screwdrivers (T40 and T20)
  • #2 Phillips screwdriver
1) Remove the 2 torx screws (T40 or T20) from each downtube:
Accessing the top torx screw where a glovebox or knee bolster is present will require lowering the glovebox door or removing the knee bolster [as described previously].
2) Provide clearance under the dash center fascia for the top of each downtube by either of the following:
Partial removal of the center console (steps 3 - 7)
Partial removal of the dash center fascia (steps 8 - 9)
3) Remove the gearshift surround:
Pull gently straight up so you don't break any of the 4 pins holding it to the center console.
Pull the surround up as far as possible to avoid creasing the leather while you work.
4) Remove the side-mirror adjustment unit:
Reaching through the opening behind the gearshift, depress the two metal prongs and push up from underneath the unit to pop it up.
5) Remove the 2 Phillips-head screws now visible.
6) Remove the Phillips-head screw from the middle of each cupholder.
7) Provide clearance:
Lift up the console to reveal the polystyrene piece under each downtube, and carefully remove each piece, allowing the downtubes to drop down.
Go to step 10
8) Remove the T20 torx screw that secures lower passenger side edge of the dash center fascia near the airbag panel:
9) Provide clearance:
Pop the lower clips of the fascia by grabbing its lower edges and giving a medium sharp tug.
Pull the fascia outward just far enough for the tops of the downtubes to clear.
10) Remove the downtubes:Angle the downtubes toward you, pulling the tops under the dash center fascia, and lift them out of the center console:
Old Jun 2, 2006 | 07:46 AM
GBMINI's Avatar
GBMINI
The instructions copied here don't apply to cars built from about March 2005 - the downtubes can't be pulled up & out of the floor on newer cars!
See http://www.gbmini.net/mtblog/archive..._downtub.shtml
Old Jun 2, 2006 | 10:30 PM
WhiteDogs's Avatar
WhiteDogs
Thanks!
Thanks, all, for the great references. Armed with this I'm off to try again!
\pat
Old Dec 11, 2006 | 03:25 PM
GoodFinder's Avatar
GoodFinder
Thanks for the question and the responses. I just received my new JCW leather downtubes with red stitching, for my GP, and now I've got a DIY project, to get them installed!
09R56
Nov 16, 2022 10:49 AM
cerenkov
Apr 24, 2018 07:47 AM
Mib4840
Oct 13, 2015 10:10 AM
ltjpunk7
Sep 6, 2015 07:32 AM
greekzilla
Aug 23, 2015 03:44 PM
