LSD and ruff rutty roads?
Old May 25, 2006 | 01:18 PM
willymcd's Avatar
willymcd
Anyone notice in ruffer or rut like roads that you MCS with LSD will pull all sorts of directions? or is this just something that is happening to me. i just checked and corrected my tire pressure to 36 PSI at all 4 corners.
I have a 05 MCS with LSD and i have had it in SLC utah up till a few weeks ago, i am now in Portland oregon for the summer, and the roads are ruffer around here, and my mini is all over the place!
Perhaps something is wrong???
Old May 25, 2006 | 02:04 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
May not be the LSD, since my car used to "tramline" all the time but especially under brakes where the ruts were exaggerated near stop lights. I have 215/40/17 tires, and thought it might be the wide tires, but since I put some negative camber on my front wheels, the tramlining has gone (significantly and almost totally gone, I should say.)
cheers,
Old May 25, 2006 | 02:14 PM
MY_05_BRG's Avatar
MY_05_BRG
rough road
i found that it happens to me as well. my mini likes to ride in the ruts in the motorway from all of the truck traffic sometimes the mini thinks it can drive itself down the road . anyway the road is the probulm not the mini or the driver the springs are tight and unforgiving a friend that weighs @300lbs got in my mini and it barely squaded hope that this info helps by the way your roads cant be any worse than the British
xSpartanCx
Dec 9, 2015 08:35 AM
IrishMCS
Dec 1, 2015 04:21 PM
Anakist
Sep 23, 2015 08:05 PM
Greezyman
Sep 21, 2015 05:31 AM
pewx3
Sep 19, 2015 12:43 PM
