Auto lock not working
Old May 25, 2006 | 09:51 AM
VAmini's Avatar
VAmini
For the past week or so, I've had some issues with my passenger side door. The lock does not respond to either the key unlock button or the central lock toggle switch. In order to lock it, I have to reach over and push the button down. (Major bummer, I know!) And in order to unlock, I have to open the door from the inside. Has anyone heard of this happening before?
Other than that, my MINI has performed almost flawlessly for 3+ years and 70K+ miles.
Old May 25, 2006 | 10:04 AM
Dr Obnxs's Avatar
Dr Obnxs
Since the rest work...
it's probably the wiring to the solenoind that works that door, the solenoid, or the driver on the BC1 that controls that lock. I don't think there's an easy way to tell without getting the car scanned (the BC1 may have an error code that helps with diagnostics) or taking the door panal off and doing some testing/troubleshooting.
Matt
Old May 26, 2006 | 03:16 PM
wozzel's Avatar
wozzel
lock not responding to remote or central lock toggle switch
Same thing here only with the driver's side door.
I'm wondering if the chronic "film"/moisture on the inside of the window and the persisitent mildew smell could be related or causal.
The dealer never satisfactorily solved those issues and will not cover the door lock under warranty as I now have 52K miles.
Old May 26, 2006 | 05:29 PM
89AKurt's Avatar
89AKurt
Scottsdale dealer just fixed mine under warrantee week before.
Old May 27, 2006 | 08:16 AM
Dr Obnxs's Avatar
Dr Obnxs
Any clue...
what they did? Wiring, solenoid or BC1?
Matt
Old Jul 21, 2006 | 11:00 AM
GRNSTRK2's Avatar
GRNSTRK2
Reviving this thread, as our passenger door just started this behavior as well. Also out of warranty, so knowing what was done would be a huge help.
Old Oct 24, 2006 | 06:42 AM
norm03s's Avatar
norm03s
Bump, Sorry to see this same thing over and over
Yeah I'd like to know too!
The larger problem is people that use the forum but don't post the resolution after they get what they wanted out of it.
Some of us out here that are out of warranty are here so we can learn about/fix/maintain our MINI's ourselves.
This is supposed to be a forum, discuss, share and disseminate information about MINI's.
Old Oct 24, 2006 | 06:49 AM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
It happened top me a few months ago. I took it to the dealer and it was a 400 dollar fix. I had to get a new motor for the locking mechanism and labor, or at least that is what I was told. I can look up exactly what the service reciept said when I get home after work.
Old Oct 24, 2006 | 08:32 AM
Dr Obnxs's Avatar
Dr Obnxs
Well, I think that's probably the least painfull it could have been...
other choices were the BC1, not cheap, or a wiring harness, not easy to change..... But the price was still a bummer!
Matt
Old Oct 24, 2006 | 08:56 AM
90STX's Avatar
90STX
Same thing happened to my driver's door latch around 85,000 miles or so. Waylen (Way Motorworks) replaced the latch and everything is back to normal again. Contact Waylen for specifics.
Scott
90SM
Old Oct 24, 2006 | 10:51 AM
norm03s's Avatar
norm03s
golden_child, that would most certainly be appreciated.
Just to be clear about the problem with my MCS is the only way to lock or unlock the drivers side door is with the key.
This just happened one day, one day it worked next day it didn't.
Am I spoiled by convenience.
Old Oct 24, 2006 | 11:05 AM
90STX's Avatar
90STX
<Just to be clear about the problem with my MCS is the only way to lock or unlock the drivers side door is with the key.
This just happened one day, one day it worked next day it didn't.>
My symptoms exactly. Yes, it is annoying and the remote unlocking is addictive. It's your latch, and the part cost should be less than $300. Call Waylen and he can help you out. No need to go to the dealer for it, unless their parts pricing is competitive. Way might be able to get it cheaper for you.
Scott
90SM
Old Oct 24, 2006 | 11:32 AM
norm03s's Avatar
norm03s
Scott
90SM
Was it the latch or a broken part in the latch or is it an adjustment. I need to look this up in my manual to see if the parts are exploded for the door latch. Maybe there is a TSB on it.
Would you PM him ( Way ) to join this thread.
Old Oct 24, 2006 | 03:04 PM
90STX's Avatar
90STX
Electronics are not my thing, but I suppose it was a relay or solenoid that actually failed. The latch comes as an assembly, not individual pieces, so it doesn't really matter too much.
Waylen was in England racing at Donnigton Park this past weekend, so I'm not sure how available he is to join a thread. However, he can be reached at miniguru7@yahoo.com or via cell at 317-201-8670. I'm not giving out secrets, as he is a NAM vendor. I suspect the email might be pretty full since he's been traveling for awhile (and going to the west coast soon too), so the phone might be your best bet.
Scott
90SM
Old Oct 25, 2006 | 05:44 AM
norm03s's Avatar
norm03s
bump, lets get these two threads together
Old Oct 25, 2006 | 05:53 AM
ProfessorDave's Avatar
ProfessorDave
That's kookie talk. I have 800 miles left before my warranty is up, and will be having this fixed (drivers side) Friday (I'll post what the exact problem is...don't want to be one of those who don't provide closure!). But I'd live with it if I were out of warranty.
Old Oct 25, 2006 | 07:44 AM
norm03s's Avatar
norm03s
Thanks, ProfessorDave
I'm out of warranty but determined to fix it myself without going to the dealer for the GOLDEN fix of a door latch for $300.00-$400.00, that's just stupid outrageous.
That money could be used for a new set of tires.
goldenchild, did you find that info on this problem?
By the way all info provided is much appreciated.
Old Dec 7, 2006 | 11:41 AM
norm03s's Avatar
norm03s
Bumpity bump, not fixed yet, still using the key and Winters here........ nuts
Old Dec 7, 2006 | 11:55 AM
golden_child
Yikes!!! I forgot I was going to post info on the door lock. I'll look once I get home. I just sent myself a reminder email.
Old Dec 7, 2006 | 12:08 PM
norm03s's Avatar
norm03s
Thanks, looking forward to what you got.
Old Dec 7, 2006 | 07:10 PM
golden_child
here you go.
LABOR
Electrical Tech(s): 109 $268.00
RT doorlock Inop
Internal Failure of lock actuator
Replace Passenger Side Door lock assembly. Function test. ok
PARTS
51-20-0-556-769 Door Lock $83.33
plus shop supplies and tax the grand total was $360.83
Old Dec 8, 2006 | 09:52 AM
norm03s's Avatar
norm03s
Dang, tuff to get to and gold plated to boot.
Thanks for the part Number, I'll contact Classic to buy the part.
This will have to be a warm weather fix, may wait till Spring.
Old Dec 8, 2006 | 09:57 AM
golden_child
This was the passenger side. I don't know if there are left and right part numbers
Old Dec 8, 2006 | 10:45 AM
norm03s's Avatar
norm03s
Your probably right on that one, I've dealt with car door locks before on other cars.
So now at 52K I'm replacing a electric door lock and a Getrag:
BACKUP LIGHT SWITCH
23140409754
I have to say this, I drove a 1997 Saturn SC2 from 7 miles to 163,000. miles and never had a electric door lock, electric window or backup light switch problem.
Are we sure they aren't sourcing parts from Lucas, I have had my share of British sports cars
Alexander Graham Bell invented the telephone. Thomas Edison invented the light bulb. Joseph Lucas invented the short circuit.
Lucas -- inventor of the first intermittent wiper.
Lucas -- inventor of the self-dimming headlamp.
The three-position Lucas switch -- DIM, FLICKER and OFF.
The other three switch settings -- SMOKE, SMOLDER and IGNITE.
The original anti-theft devices -- Lucas Electric products.
"I've had a Lucas pacemaker for years and have never experienced any prob...."
If Lucas made guns, wars would not start either.
Did you hear about the Lucas-powered torpedo? It sank.
Old Dec 15, 2006 | 09:36 AM
norm03s's Avatar
norm03s
Aha, Door locks again!
