Vibration
Old May 22, 2006 | 12:45 AM
dairyboy's Avatar
dairyboy
Vibration
I've narrowed it down to this - there's a vibration felt (not through the steering) but the body seems to be shaking a fair bit in 2nd gear at 2-2250rpm under load and at about 25mph. However, if it's at the same speed and rpm except only part throttle it (about 1/2" pressed down) then the vibration can't be felt.
Same thing occurs under load at about 3k rpm in 4th gear, at around 60 mph. After that it's silky smooth.
Question: is this an mount issue? However, didn't really felt this before until I had my shocks and springs replaced along with a rear camber arm fitted. My mech blames it on the rear camber arm but I am sure that's not the case.
Old May 23, 2007 | 07:32 AM
retroom's Avatar
retroom
Vibration
Hi,
I am getting the same symptoms. Did you find the cause of the vibration?
Thanks,
retroom
Filmy
15
Jun 6, 2023 06:27 AM
minieater
Oct 28, 2015 02:15 PM
BlueCooperS
Sep 25, 2015 10:06 AM
gpwpat
Sep 15, 2015 11:58 AM
Suspension Products
Sep 10, 2015 11:46 AM
