R50/53 '06 airbag stickers
Old May 20, 2006 | 02:01 AM
fms's Avatar
fms
'06 airbag stickers
I just tried the same goo-gone technique I used on my '03 MINI to try to remove the sunvisor airbag stickers on my new anthracite headliner '06 MINI, thinking it would be as easy as the first time, and man- they just don't want to come off! I rubbed and rubbed w/ a goo-gone soaked paper towel, and the suckers just don't want to shrivel and peel. Has anyone had success in taking the visors off, and do you have a pic showing how?? I can't get to the screws, since the base of the swivel has both screw holes covered w/ plugs, and it seems that no screwdriver can get them to pop off w/out damaging the plastic. Argghh, having had no problem before, I thought this would be a piece of cake to do!
Old May 20, 2006 | 05:39 AM
thebill's Avatar
thebill
denatured alcohol or mineral spirits, or search it.
Old May 20, 2006 | 06:40 AM
Jersey_Bill's Avatar
Jersey_Bill
Also acetone (nail polish remover). I got mine off with that and a cotton ball but remember that it seemed to take 20 minutes each of rubbing before the stickers started to disintegrate. They are rubberized and will roll off eventually. You will unfortunately see a slightly shiny spot where the stickers used to be - but it is not very noticeable.
The sticker on the dash can almost be peeled off - and goo gone works fine for that one.
Old May 20, 2006 | 07:17 AM
qwertmonkey's Avatar
qwertmonkey
Did you try Goof Off?
Old May 20, 2006 | 09:37 AM
rhawth99's Avatar
rhawth99
I covered both of mine with the MINI CD holder - looks great and practical, too.
Old May 21, 2006 | 12:20 PM
Drillslinger's Avatar
Drillslinger
I used the Frau's Hair Dryer to heat them up, then used a butter knife to lightly "Scrape" them up and off. Goo-Gone helped get the last bit of residue off
Old May 21, 2006 | 06:02 PM
capnmini's Avatar
capnmini
I dunno, but i took my stickers off with a swiss army knife, yeah it did take a while but there was no residue left behind
Old May 21, 2006 | 06:18 PM
claancy's Avatar
claancy
I took the airbag stickers off my 06's visor with denatured alcohol. Took the visors off the car first, so I didn't need to worry about getting the alcohol anywhere I didn't want it to be. I pried out the screw covers out with a very small screwdriver, I think that they had clips on all of the flat sides. Then take out the screws, unplug the electrical wiring and they're out.
To actually take the stickers off, I folded up a paper towel so it was just bigger than the sticker, and soaked it in the denatured alcohol. Then, let it sit on top of the sticker for a while...probably 15 minutes or so...until the sticker shrivels up. Then, I started at a corner and genly peeled the sticker off. Try to get it off in as few pieces as possible.... on the second visor, the sticker only wanted to peel partway off, so I folded it back and let it soak under the paper towel a little longer. After I got the sticker off, I soaked the area a little more to loosen up the residual adhesive. Then with some rubbing, with another paper towel soaked in the denatured alcohol took off the adhesive. When I was done, I wiped the visors off with some soapy water, and treated them with some interior vinyl protectant.
They turned out pretty well.... just a little shadow where the sticker had been.
Old May 21, 2006 | 10:32 PM
Chili Pirate's Avatar
Chili Pirate
I've ordered a sticker that says "no bra" and hold on tight etc. Hope this covers those pesky things. ciao, Bill
Old May 22, 2006 | 07:39 AM
roddw's Avatar
roddw
Bill,
Who did you order your stickers from?
thanks!
Old May 22, 2006 | 09:55 AM
Moskito's Avatar
Moskito
I solved the issue by creating stickers which fit over them.
Here is the one for the passenger side:
And this is the one for the driver's side, but could easily by used on the passenger side too:
Herbert
Old May 22, 2006 | 10:30 AM
mini-mine's Avatar
mini-mine
lol, that's a hoot!
Old May 22, 2006 | 12:11 PM
Chili Pirate
roddw, On Ebay, indelibleimaging 54579 or minicooper sticker"-NO BRA- warningfunny" Waiting for it, if it fits will get something for the other side. Ciao, Bill.
Old May 22, 2006 | 12:16 PM
DrDiff's Avatar
DrDiff
Coordinator :: Northwest Indiana MINIacs
MIB has one of these. Just slightly larger than the air bag sticker. See my gallery... My Mother-inlaw loves it!
Old May 25, 2006 | 11:37 PM
chrisneal's Avatar
chrisneal
Originally Posted by claancy
Took the visors off the car first... Then take out the screws, unplug the electrical wiring and they're out.
How does the wiring unplug? There doesn't seem to be any pinch-type tab release or anything else obvious.
Old May 26, 2006 | 09:46 AM
chrisneal's Avatar
chrisneal
bump...
Come on, I know lots of people have done this. Why the heck are there wires going to the freaking visor anyway? What if I just snip them? What'll happen then? Will it fry my ECU and void my warranty? Will I lose the capability of enabling "automatic visors" in the future?
Old May 26, 2006 | 10:02 AM
Minitee's Avatar
Minitee
I think the airbags deploy immediately when you cut that wire. Do your visors have vanity lights in them? If so, I suspect they won't light up so well after you cut the wires.
Wish I could help with your underlying question.
Old May 26, 2006 | 12:33 PM
chrisneal's Avatar
chrisneal
Oh yeah. Sorry, my brain is just fried this week.
All I know is, I've read dozens of posts here about people removing the visors to get the stickers off, so I'm puzzled by the difficulty of getting an answer to this question... I'll go try another search.
Old May 26, 2006 | 12:39 PM
chrisneal's Avatar
chrisneal
OK, I found this thread, in which Rick-Anderson says "Carefully disconnect the wire connector – they pull apart with no clips."
I guess I'll try again when I get home.
Old May 26, 2006 | 12:46 PM
cindy2627's Avatar
cindy2627
Grin sticker
Moskito - I love the grin! Who made the actual stickers for you? I'd love one of those.
Cindy
Old May 28, 2006 | 12:41 PM
chrisneal's Avatar
chrisneal
Anyway, I eventually pulled the wires apart, but the ones on the drivers side were REALLY hard to pull apart. I actually used so much force that I assumed I was going to break it (didn't care at that point), and they finally came apart.
I used a paper towel soaked in denatured alcohol, folded to the size of the sticker - slightly larger, actually. Even replenishing the alcohol periodically so keep it moist, it took a full hour for the sticker to bubble up enough to get it off, and even then it didn't just peel off like others have said. I got a few pieces off that were an inch or so long, but mostly it came up in tiny pieces, and I ended up using my thumbnail to scrape it off. It also left behind a substantial residue that the denatured alcohol was powerless against, so I used Goof Off to finish the job.
All in all a major pain in the ***, but I suppose it's worth it. I just wanted to post this to let people know it's not necessarily as easy as other posts make it sound. I don't know if this is because my car is a year old, so they had more time to bake on there, or what.
Old May 29, 2006 | 02:24 AM
DaveTinNY's Avatar
DaveTinNY
I juts ordered two of the "bra" stickers off eBay. Made me laugh. :-)
Old May 30, 2006 | 08:34 AM
AMW's Avatar
AMW
I made the mistake of rubbing a paper towel soaked with denatured alcohol over the sticker a bit, which took off the lettering and spread dingy small black specks across the porous surface of the visor. I realized what was happening and then just let the sticker soak in the stuff and eventually got the sticker off. But now where my sticker was, I've got a dingy shadow of tiny black specks. Anybody know a good way to get rid of these? I tried scrubbing with a nylon brush and soap (also tried the same + toothpaste). Neither really cleaned it up. I left the passenger sticker on after this experience.
Old May 30, 2006 | 08:39 AM
chrisneal's Avatar
chrisneal
I definitely wouldn't recommend attempting this with the non-anthracite headliner. Luckily mine is dark, because I probably have those same black specks. You might try a more powerful solvent such as Goof-Off, but I have no idea of it would work, and how many of these chemicals do you really want to purchase and have hanging around just to get rid of some silly stickers? Good luck!
Old Aug 18, 2006 | 01:21 PM
purplefreak60's Avatar
purplefreak60
check out aestheticreations.net - Mike now offers cool stickers to place over the warning sticker!
