Suspension Can Realignment Fix Rubbing (M7 Springs)?
Old May 19, 2006 | 05:34 PM
NV MINI's Avatar
NV MINI
It has been 4 days since installing M7 springs on 215/35/18’s (I was told to wait approximately a week before realigning the car). When I was driving back home on the freeway I was getting a rub on the rear driver side wheel every time I hit a dip or bump going 65-70mph on the freeway (about 5-6 rubs on the 20 mile trip home). By the way, getting no rubbing on surface streets.
I was assuming that having the car aligned would fix the rubbing issue on that side, but a friend of my brother said, it wouldn’t. I called the shop that installed my springs and they said it should fix the problem.
I just wanted some input from NAM prior to getting the car aligned/checked out this Tuesday, or if anyone else has experienced the same problem. –NV MINI
Old May 19, 2006 | 05:40 PM
cooldaddy's Avatar
cooldaddy
my guess is that an alignment may actually make it worse - with the M7 springs installed the rear camber increased and actually created a little more clearance - if you get the car aligned and the rear camber adjusted back to normal (only adjustable on 05 and later and only 0.5 - 1 degree or something) the tires will get closer to the fender...
I ended up trimming the plastic inside the fender as my 215/45/17 on 17x7.5 with 40 mm offset and M7 springs was rubbing big time front & rear. After 2 rounds with the dremel I'm almost "clear"...
what size wheels and offset do you run?
Old May 19, 2006 | 06:12 PM
kenchan's Avatar
kenchan
you can most likely fix it by giving it a tad more neg camber on the back, but i'd first find
where it's actually rubbing before taking her in.
you need to specify to the alignment tech that your primary is to
rid rubbing, then trying to get it as close to factory spec.
Old May 19, 2006 | 06:28 PM
Urban_Assault_JCW's Avatar
Urban_Assault_JCW
on a lot of lower cars I've done that had rubbing issues we just rolled the fenders. Baisically you just bend the metal lip on the inside of the fender or take off the tire and cut the lip off will a dremel or grinder ect... If that's what is rubbing its a simple fix that won't damage the car and isn't noticable at all just take your time and be careful if you do it.
Old May 23, 2006 | 08:53 PM
defylogik's Avatar
defylogik
18s are also pretty big for a car this small, you are probably going to have to trim trimmy trim trim.
Old May 28, 2006 | 03:21 PM
NV MINI's Avatar
NV MINI
It’s been 5 days since realigning the car, and there’s no longer a rubbing issue on the rear drive side wheel as previously mentioned.
Old May 28, 2006 | 04:26 PM
onasled's Avatar
onasled
If you increased rear negative camber to fix this then just drive safely as your car will have quite a bit of increased understeer.
DevilMeTaz
R60/R61 Stock Problems/Issues
Oct 2, 2015 06:44 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 3, 2015 02:06 PM
Suspension Products
Sep 3, 2015 09:41 AM
Llanrhaeadr_Cymru
Country Roads MINIs
Sep 2, 2015 07:12 PM
