Direct thread or Banjo, how do I tell?
Old May 17, 2006 | 02:53 PM
SOCRATES's Avatar
SOCRATES
Hi All:
Forgive me if this has been posted already, but I'm trying to figure out which of these two I have on my 2006, as I'm trying to get a rear kit to match my TCE front BBK.
I need to know if I have rear hoses with direct thread to the caliper or if I have
a banjo and banjo bolt on the end into the caliper body.
How exactly can I tell which I have?
Thanks in advance,
-Justyn
Old May 17, 2006 | 04:42 PM
SOCRATES's Avatar
SOCRATES
Anyone?
Old May 17, 2006 | 06:00 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Banjo fittings usually have a bolt head with the line coming it perpendicular to the bolt. Direct thread have the line attached inline with a hex wrenching surface.
Banjo fittings are named for their resemblance to a banjo, a round open ring end with a perpendicular 'neck' which is the line itself.
Old May 17, 2006 | 06:31 PM
jimz68's Avatar
jimz68
Direct thread in the rear.
Jim
Old May 17, 2006 | 06:46 PM
SOCRATES's Avatar
SOCRATES
Thanks to the both of you. Actually, I'm told that I could have either one on my 2006, so I will check tomorrow. Thanks again for the prompt replies.
-Justyn
Old May 18, 2006 | 07:24 AM
toddtce's Avatar
toddtce
My gut feeling is direct also. But I've seen banjos on later cars now as well. Seems BMW is sourcing two parts I guess.
Direct is just that: the rubber hose has a steel end and simply screws into the caliper on the side. The hex on the end of the hose is a M14 wrench.
Banjo has a steel end on it with a hex bolt and crush washers to seal it, passing into the caliper body. The banjo bolt will have a large hex head to it- perhaps M17 or M19 wrench needed.
Old May 18, 2006 | 12:17 PM
SOCRATES's Avatar
SOCRATES
Stuck my head in there this morning, it was a direct fit line. My calipers are on the way to you, Todd. Can't wait to get the rear kit fitted (as well as the front). Thanks!
-Justyn
Old Jun 30, 2006 | 07:56 AM
62Lincoln's Avatar
62Lincoln
This description helped me tremendously. I thought I would attach a photo of my direct line so that future searchers will have a visible guide also:
Old Jun 30, 2006 | 07:26 PM
toddtce's Avatar
toddtce
I'm saving this one for future reference. Hope it will help everyone looking at rear rotor kits!
Old Sep 8, 2006 | 05:39 PM
etalj's Avatar
etalj
hey guys these are pics of my brake lines.
Do i have direct threads or banjo threads?
Elie
Old Sep 8, 2006 | 05:43 PM
etalj's Avatar
etalj
Old Sep 8, 2006 | 06:05 PM
FUEGO's Avatar
FUEGO
That would be direct thread. The first pic shows the brake line 'directly threaded' into the caliper body.
Old Sep 8, 2006 | 08:46 PM
etalj's Avatar
etalj
thought so. thanks!
Old Sep 9, 2006 | 10:22 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
So...is a banjo better, same or worse than a direct thread?
Old Sep 9, 2006 | 10:32 AM
toddtce's Avatar
toddtce
Your'e making waaayyy too much of this. It's just for ID of the type of rear hose kit you need to replace the rubber lines.
It doesn't make a hill of beans difference on the car. Unless you get the wrong ones and have the car torn apart in the drive way on Saturday afternoon....
Old Sep 9, 2006 | 10:35 AM
Agro's Avatar
Agro
Ok...so banjo lines won't go into a direct thread caliper?
Old Sep 9, 2006 | 10:39 AM
toddtce's Avatar
toddtce
What would be the point? You got a set you want to make work? You could drill out the current hole, tap it M12 and make them work.
Old Sep 9, 2006 | 03:14 PM
Agro's Avatar
Agro
I'm asking because I've seen a couple of vendors lately advertising "we're clearing out these braided/stainless brake line sets with banjo fittings".
I have factory 03 brakes, which it appears are probably direct thread. Now I know that these clearance brake lines are no use to me.
Klenk
GP Talk
Sep 16, 2015 11:29 PM
Sep 10, 2015 01:50 PM
Sep 10, 2015 01:48 PM
Sep 10, 2015 10:52 AM
Norton70
Sep 7, 2015 05:06 PM
