R50/53 Dynamic headlamp range... say what?!
I was taking a look at the 2005 pdf manual and in the parking lamps/low beams section, I saw this entry: The dynamic headlamp range control for xenon lamps only operates with the light switch in position 1 or 2.
What the heck is dynamic headlamp range control and why is there no more info in the manual? I don't have my MINI yet so I can't go out to it and check it out.
Xenons tend to come from the factory pointing too far downward. Just re-adjust them up and you'll have some improved (if not dynamic) headlamp range!
Originally Posted by DownSize
yeah, when Iget my fog lamps tomorrow, im gonna do that. is it counter clockwise to reaise them ? or clockwise. I gotta find that old thread
What I do remember is that it does not take much of a turn to get a noticeable change. I would do 1/4 turn at a time. I don' think I did much more than 1/2 turn of the adjustment screw.
also, if anyone else planned on adjusting them, the headlights need to be on and let it go through the auto leveling feature. if the headlights are not on while adjusting, once you turn them on, they will just go back to a preset level. sorry for the hijack, i thought alot of people would like to know.
Please have someone help you check your lights after you adjust them! Have them drive in front of you at night to make sure your lights aren't pointed too high.
I for one don't want to end up with someone driving behind me at night with an improperly adjusted xenon headlight blinding me every time I look in my mirror.
Thank you!
Thank you!
Originally Posted by chows4us
it means simply that they are self-adjusting at all times (e.g., while braking, while accelerating) and it does apply to the US as well as Europe.
Its an adjuster for the Xenons that looks sillilar to the gauge backlight adjuster on a Ford.
I'll see if I can find a picture...
Originally Posted by not-so-rednwhitecooper
I believe the feature he is refering to the the **** that fits into the blank spot on the parcel shelf or European cars.
Cool
I know for sure that I adjusted MY xenons with the lights off, and they adjusted just fine.
Yucca knows of what he speaks. I started with a 1/4 turn, and that was way too much. About 1/8th took me from staring at asphalt in front of me to seeing the road ahead.
RobbyD
Jan 29, 2019 01:22 PM
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
