1st gear rough and low oil level
Old May 11, 2006 | 09:05 AM
makmini's Avatar
makmini
The past 2 weeks I noticed that engaging 1st gear in my MC40 at low rev's has been rough and loud. I'm not sure what the oil dipstick should normally look like at proper oil levels but it did appear to be low. I added a quart of synthetic and drove around for a couple miles and rechecked the levels. The dipstick looked a little better and 1st gear *feels* a lot smoother.
I tried searching for 'oil light' issues but is anyone aware of any known issues with the low oil light sensor not going off? Kinda scary that there was no warning from the computer about low oil levels.
I think I might as well change the oil at this point for good measure.
Old May 11, 2006 | 09:14 AM
gr8britwjh's Avatar
gr8britwjh
The dipstick checks the engine oil level; it has nothing to do with your transmission.
Also, did you make sure your engine was at full operating temperature and then allow sufficient time for the oil to drain back before you checked the oil level (if it hasn't all drained back to the oil pan you will get a low reading on the dipstick when, in reality, it's not low). Too little oil = bad and too much oil = bad. Never trust the warning light. You should check your oil level regularly.
Old May 11, 2006 | 09:47 AM
fred3's Avatar
fred3
You might also want to consider learning how to read a dipstick. It's not that difficult and you can do damage not only by allowing the oil to get too low, but by overfilling it too.
Old May 11, 2006 | 01:44 PM
makmini's Avatar
makmini
I understand that it has no direct correlation with the transmission- however, I felt like the engine didn't have to work so hard - i.e.- lubrication of the pistons, when there was a more adequate level of oil.
Old May 11, 2006 | 04:08 PM
kapps's Avatar
kapps
Just make sure the oil level is between the marks. The engine's still getting good lubrication even if it's on the lower mark. Too high an oil level will cause some serious damage from too much pressure.
Old May 12, 2006 | 08:21 AM
makmini's Avatar
makmini
thanks - I've noticed my mileage has since gone up and idle is smooth now. I'm getting 33.1mpg on each tank now. I do about 90% highway driving on my commute.
Old May 12, 2006 | 08:29 AM
Dolmangar's Avatar
Dolmangar
To be honest, the dipstick in the MINI (at least on the 06 S) is terrible, and considering that you have to twist it, cross your fingers, and pull at just the right angle to to get it out and once you do get it out, the markings aren't easy to read, or clear on what is "just right".
It's a shame too, since I suspect that many of the people who own MINIs are more then happy to get under the bonnet and make sure that their baby is well taken care of, which means that they are constantly having to battle with the crap-tastic dip-stick.
Old May 12, 2006 | 09:18 AM
makmini's Avatar
makmini
yeah, I'm afraid of mangling something when I pull it out or try to put it back in.
Old May 12, 2006 | 09:19 AM
kapps's Avatar
kapps
Yeah, the MCS dipstick leaves much to be desired. I use the method of taking a rag between my fingers and squeezing it around the dipstick. The oil will come off onto the rag where it's much easier to see.
sevin
May 2, 2026 06:11 AM
Emnotek
Aug 13, 2015 05:47 PM
Aug 12, 2015 01:24 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
