Seat Height Adjuster problem
Old May 10, 2006 | 09:25 AM
Dugmar's Avatar
Dugmar
I have an '02 Cooper S, US, LHD.
The height adjuster only raises the seat, I cannot get it do lower. I don't want to force the lever too hard. It is the wratcheting lever on the left. Any ideas or tricks to fix this? The dealer wants almost $400 for just the seat bracket assy.
Thanks,
Doug
Old May 10, 2006 | 09:34 AM
jreaney's Avatar
jreaney
Sit on it
Are you sitting on it - It will not lower without weight on it.
Old May 10, 2006 | 09:38 AM
Dugmar's Avatar
Dugmar
All 255LBS of me, which is probably what broke it to begin with.
Old May 14, 2006 | 11:20 PM
Frodo's Avatar
Frodo
Dugmar,
I have had the exact same problem with my 03. Since my warrantee expired (I am overseas with a 2 year warrantee),I took it apart this weekend. There are several rivets that have to be drilled out. The problem is a plastic cup inside that broke. I solved the problem, temporarily, by turning the cup around and pop riveting the assembly back together. Now it only goes down . The whole unit should be replaced but I do not know the part number. If your warrantee is good have the dealer replace it. I am looking for the part number now...If anyone know it please chime in.
Regards,
Frodo
Old May 15, 2006 | 05:16 AM
Rev. Limiter's Avatar
Rev. Limiter
Part number for your seat is here.
Looks expensive...
Old May 15, 2006 | 07:38 AM
findude's Avatar
findude
This has become very problematic for me. When my wife (5'0") drives the car the seat is so far forward that I (6'2") cannot get in. I have to put one hand on the seat and lean on it in order to ratchet the lever with the other hand.
The MINI seat adjusting mechanism is probably its major design flaw. All of our other cars have power driver seats with memory buttoms, but the MINI does not offer this work-around. If anyone from MINI is reading this, please note that we would gladly have paid megabucks for this option!
Our work around is that we take turns with the MINI on intervals of a week or more. It simply isn't worth the trouble . . . . .
Old May 15, 2006 | 02:08 PM
DownSize's Avatar
DownSize
atleast the seat still scoots. I had that problem on my old car not fun at all!
Old May 24, 2006 | 02:19 PM
Ben's Avatar
Ben
I have an 03 MCS and have the same problem. I have an appointment with my Service Advisor on Tuesday 5/30. I'll let you know what the verdict is. I need to get it fixed so we'll see what the damage is.
Old May 24, 2006 | 10:59 PM
jerjer's Avatar
jerjer
mine is broken too..it's stuck, only can pull or push once.. and thats all it does..haha, i need to take it in for a look.. and i have like a million other problems i have to address to the dealer..omg !
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
minicoclub
Nov 11, 2015 07:25 AM
Zettinger
Aug 25, 2015 04:04 PM
minicoclub
Aug 25, 2015 09:07 AM
messyjesse96
Aug 12, 2015 05:51 AM
