Interior/Exterior Looking for a new antenna
Old Apr 22, 2006 | 08:54 AM
muggy's Avatar
muggy
I'm tryin to find a new antenna, I like the kind that have a bend in them so you can tilt them back at an angle. Anyone know a good place to pick up one of these? I prefer black and under $25 if possible, but I'm open to whatever you guys can throw out there.
Old Apr 22, 2006 | 06:08 PM
Snappychip's Avatar
Snappychip
S2000
Go with an S2000 antenna works good and you can get em at a Honda dealer for $22 or maybe find it cheaper online probably.
Old Apr 22, 2006 | 06:23 PM
Methman's Avatar
Methman
I threw on the 4" Alta. Here's a link:
http://www.triple-c.com/Store_Detail...41&SnipID=5393
Old Apr 22, 2006 | 08:14 PM
SonicVI's Avatar
SonicVI
I like the S2000 antenna too, not too long and not too short, and matches the matte base 05-06's. I got one on ebay for $12 plus postage.
Old Apr 22, 2006 | 09:09 PM
jerjer's Avatar
jerjer
i think the s2000 antenna, at least the one i have, is alittle too thick and bulky in size. i'm in the look out for a better soft and short antenna, which ain't easy to find.
Old Apr 22, 2006 | 09:18 PM
Snappychip's Avatar
Snappychip
I hear also the Lexus RX antennas look good too.
Old Apr 22, 2006 | 09:22 PM
gokartride's Avatar
gokartride
I've never seen one....ever.......that was bent back at an angle. If you find one do let us know. In '03 I got an S2000 antenna which has worked fine, but if I were to do it all over again today I'd go Alta.
Old Apr 22, 2006 | 09:32 PM
cycleguru's Avatar
cycleguru
Yea, I was thinking the same think. I don't think I've ever seen one that tilts back. But if you ever find one Muggy please let us know.
Old Apr 23, 2006 | 09:09 AM
muggy's Avatar
muggy
I'm pretty sure I've seen them by chance when flipping thru stores that sell other car accessories, but I don't think I've seen them on MINI specific websites.
I was contemplating bending the stock antenna and shaving off some of the rubber, as I don't use the stock antenna at all. I'll post some pics if I actually do this.
Anyone know if that empty hole will rust up? I might need to find something for that.
Old Apr 23, 2006 | 09:18 AM
gokartride's Avatar
gokartride
I did see an antenna that you could make longer/shorter by cutting a metal rod that essentially ran up inside a base and topper. Theoretically one could bend the rod. Not sure where I saw it...ya might check Moss.
Old Apr 23, 2006 | 12:37 PM
Snappychip's Avatar
Snappychip
You wouldn't want water or anything in the hole, but i have heard some guys plug the hole with a rubber plug or tape it over. Reception isnt bad with out an antenna because of the internal antenna that I believe runs through the roof.
Old Apr 23, 2006 | 12:50 PM
SashaSolitaire's Avatar
SashaSolitaire
Check out the JOM antenna for Volkswagen....that one has a metal piece in between, which I think you can bend!!!
I use the antenna with the shorter middle piece. Pics in my gallery if u r interested
Old Apr 24, 2006 | 07:39 AM
OldRick's Avatar
OldRick
Have a look at http://www.antennax.com/
They offer a 13" plastic antenna that can be bent into a gentle curve, and at $10, the price is right...
Old Apr 24, 2006 | 10:19 AM
rkw's Avatar
rkw
Do you have a picture of it mounted on a MINI? And how wide is the bottom of the mast? Some antennas (like the S2000) flare out too wide at the bottom for the narrower, more pointy antenna base of the convertible.
Old Apr 24, 2006 | 10:29 AM
chikmagnet's Avatar
chikmagnet
this is the one that i bought for my ride
it is only 2 5/8 inches tall and still gets good reception
http://new.minimania.com/web/Item/NM.../InvDetail.cfm
Old Apr 24, 2006 | 10:38 AM
OldRick's Avatar
OldRick
I wound up sanding the base a bit for better fit, and then used some black heat-shrink tubing to improve the shape near the base. The bottom inch or so in this picture of the AntennaX 13" is my heat-shrink.
Old Apr 24, 2006 | 11:34 AM
G8RMNI's Avatar
G8RMNI
Alta Antenna = Poor Reception
I bought the Alta antenna since I heard so many great things about it. Unfortunately, the reception is horrible. I live in a very urban area (Washington, DC Metro area), so I am a little blown away that the performance is so poor.
If I put the MINI antenna on, the reception is awesome...I can't stand the R/C car look of it though.
Also, I noticed that as soon as I drive into a parking garage, the signal dies almost immeadiately with the Alta...bummer.
I think I'll try out the S2000 antenna. Hopefully I'll see better results.
Old May 19, 2006 | 11:28 AM
muggy's Avatar
muggy
http://racers.jp/mini/304/index.html
http://racers.jp/mini/346/index.html
So can anyone find anything like these in the US?
Old May 19, 2006 | 02:12 PM
hgsbnt's Avatar
hgsbnt
Many French Mini owners now change their stock antenna with a Peugeot one which costs € 5,00 about $ 6,00 or so. Reference is 6561N3.
Looks great and works fine.
Old May 19, 2006 | 03:11 PM
rkw's Avatar
rkw
Originally Posted by muggy
Interesting idea. The product itself is just a hinged joint that you screw your own antenna on. You may be able to fabricate something similar using parts from the hardware store.
Old May 19, 2006 | 06:41 PM
polizei's Avatar
polizei
I have no antenna...and I love it. Nothing uglier than that antenna....and the best part is that all you do is unscrew the antenna...and it's done! Plus it's free!
-Cody
Old May 20, 2006 | 12:24 PM
muggy's Avatar
muggy
I didn't notice that, nice eye. I'll head over to home depot when I get a chance, shouldn't be that hard to get a hinge and to cover it with a rubber fitting.
Old May 20, 2006 | 03:16 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
-Cody
if you dont want an ugly hole up there....you can also just screw in a proper black screw
Old May 21, 2006 | 06:07 AM
hgsbnt's Avatar
hgsbnt
Old May 21, 2006 | 08:35 AM
polizei's Avatar
polizei
I would like to do that....any idea on the size of the screw needed? I'm sure I have one around here....somewhere.
-Cody
