Input shaft seal leak
Old Apr 21, 2006 | 01:05 PM
ofioliti's Avatar
ofioliti
During my 2nd free maintenance check up (25K-30K) the MINI tech said he had discovered a fluid leak in the input shaft seal of the transmission. (I have the 6 speed manual.)
He replaced the seal and now the transmission feels a bit different (for the better): The shift from 1st to 2nd does not go "kachunk" anymore and overall the shifting feels more "cushioned."
Has anyone else had this problem?
Old Apr 21, 2006 | 01:10 PM
TSR53's Avatar
TSR53
I bet the BMW MINI gearoil fluid for your 6-speed Getrag gearbox is new. That would explain the more cushioned feel.
Old Apr 21, 2006 | 01:27 PM
ofioliti's Avatar
ofioliti
New in terms of replaced with new fluid or new in terms of a new formula as well?
Old Apr 21, 2006 | 01:40 PM
TSR53's Avatar
TSR53
I would possibly say both. If you have the Limited Slip Differential, there is a TSB issued Feb, 2006 to use a specific fluid if you experienced grinding noises with the LSD taper rings.
...the transmission fluid should be replaced with Texaco MTF94 trans fluid (P/N 83 22 0 403 247)... This is a new formula that helps with the grinding noise experienced by some.
If no LSD, then maybe just the new fluid swap did the trick
patsum
26
May 29, 2021 06:29 PM
Supertractor3
Apr 7, 2017 11:16 AM
CaptKen
R59 :: Roadster Talk (2012+)
11
Oct 21, 2015 06:32 AM
Sep 4, 2015 09:10 AM
Sep 2, 2015 09:05 AM
