Off-Topic :: Autos Interested in discussing other autos? This is the place!
WING or SPOILER - differences?
Old Apr 11, 2006 | 04:42 PM
chows4us's Avatar
chows4us
For the technical minded ...
What is the difference, or is there a difference, between a wing and a spoiler?
I ask this after looking at the GP "wing"
I've read, for example, that the Exige Wing is a true wing giving up to 100 pound of down pressure at speed vice the wingless Elise.
On the other hands, some Porsche literature says that the Porsche pop-up spoilers are that ... true spoilers in that they "spoil" the airflow vice producing any downforce (to keep the backend from getting light)
Old Apr 11, 2006 | 05:44 PM
kenchan's Avatar
kenchan
spoiler for me is something that is stuck on the plane of the trunk lid.
wing is something that is mounted with 2 or 3 posts.
Old Apr 12, 2006 | 12:47 PM
ThreeAlarmChiliRed's Avatar
ThreeAlarmChiliRed
On a car, a wing produces downforce. A spoiler can either prevent lift, or control flow separation off the afterbody of the car. Less noise and drag is produced by forcing the flow to separate cleanly earlier on the afterbody then to allow its separation point to oscillate up and down the after body.
Old Apr 12, 2006 | 12:54 PM
chows4us's Avatar
chows4us
Thanks, that is exactly how I understand and hence ...
They are NOT the same thing!
Old Apr 12, 2006 | 12:59 PM
Motor On's Avatar
Motor On
So whats on the back of your MCS?
Old Apr 12, 2006 | 01:05 PM
paul_'s Avatar
paul_
we have a WING, as it is not mounted along the full length of the back. stupid wing...stupid drag... lol
Old Apr 12, 2006 | 01:49 PM
ThreeAlarmChiliRed
I wouldn't call the MCS appendage a wing. The amount of flow that could make it through that slot wouldn't do much for producing lift on the underside of the, uh, appendage.
Old Apr 12, 2006 | 03:24 PM
jollygreenmini's Avatar
jollygreenmini
The "spoiler" on the MCS is for appearance only. It should be more properly called a sun shade (like on a cap), because that's about all it does.
Old Apr 12, 2006 | 06:55 PM
ThreeAlarmChiliRed
At least MINI described the GP appendage correctly.
...an aggressive rear-wing spoiler...
Translation: It does nothing.
Old Apr 12, 2006 | 07:12 PM
kenchan's Avatar
kenchan
that's a spoiler.
Old Apr 12, 2006 | 07:14 PM
Motor On's Avatar
Motor On
that's a spoiler.
Agreed.
Old Apr 12, 2006 | 07:21 PM
kenchan's Avatar
kenchan
Agreed.
doesn't have posts, that's why.
Old Apr 12, 2006 | 07:28 PM
ScuderiaMini's Avatar
ScuderiaMini
having a smart@$$ friend is priceless
Old Apr 12, 2006 | 07:31 PM
Motor On's Avatar
Motor On
But its also only on the ends.
Real wings have roots.
Old Apr 12, 2006 | 07:32 PM
Motor On's Avatar
Motor On
And I thought is was agressive and took away traction from the wheels that do the steering and driving.
Old Apr 12, 2006 | 08:03 PM
kenchan's Avatar
kenchan
Is "root" the technical term for the verticle posts of the wing?
Old Apr 12, 2006 | 08:05 PM
kenchan's Avatar
kenchan
nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn................... ................ i can't
think of a come-back!
Old Apr 12, 2006 | 08:06 PM
Motor On's Avatar
Motor On
Well I'm an aerospace engineering student and the root is where the wing attaches to the fuselage on a plane, just a bit of geek humor.
Old Apr 12, 2006 | 08:14 PM
lhoboy's Avatar
lhoboy
I'd like to see the wind tunnel smoke. As an old thermo engineer, the OEM S wing design appears to me to have a winglike cross section on the bottom producing downward "lift" (albeit minimal) and a spoiler profile on top to foil the laminar flow that creates upward lift on the roof panel. If true, combined, there might be noticeable effect instead of mere aesthetic "pimping".
Old Apr 12, 2006 | 08:20 PM
Motor On's Avatar
Motor On
Same here or even the manufacturer CAD files.
Old Apr 12, 2006 | 08:53 PM
lhoboy's Avatar
lhoboy
There's gotta be some info someplace on this.
Old Apr 13, 2006 | 06:37 AM
ThreeAlarmChiliRed
It might look like a wing, but wings need a lot of air moving over the curved, low-pressure surface -- at least 50% more than over the flat, high pressure surface -- in order to produce lift. Plus, it helps if the flow isn't a disturbed mess like you'd find behind a speeding brick.
The region at the windshield/roof junction is certainly a low pressure, lifting area, but I seriously doubt that the last half of the roof is. However, assuming that it is, cracking the sunroof to the tilted position would be a more effective spoiler.
Old Apr 13, 2006 | 08:44 AM
ThreeAlarmChiliRed
What Alfa put on the back of the Brera is a spoiler. On an afterbody of this angle, the flow will separate and reattach up and down the surface leading to noise and drag. This type of spoiler forces the flow to separate cleanly reducing both. The flow off the roof of the MINI is going to separate much more cleanly at the turn from the roof to hatch than on a fastback type design, so, on a MINI, a spoiler of this type is not needed for any functional reason.
Old Apr 13, 2006 | 11:16 AM
kenchan's Avatar
kenchan
^^ hummm... not much of a decoration either...
Old Apr 13, 2006 | 12:21 PM
ThreeAlarmChiliRed
It doesn't need decoration!
