Suspension Camber plates and strut tower bar?
Old Apr 10, 2006 | 10:29 AM
racinbmw's Avatar
racinbmw
Not sure if this question has been posted before, however I am curious to find out an answer to it.
Does anyone know if you can still run a set of fully adjustable camber plates with a strut tower bar?
The reason that I ask, is that some of the camber plates require cutting on the tower and I am curious if after cutting and installing a strut tower bar on top, if you try to run full camber, does it interfear with the bar? (meaning not able to adjust all the way)
Thanks guys
Old Apr 10, 2006 | 02:52 PM
pure&simple's Avatar
pure&simple
I have the Helix camber plates that bolt right up without cutting. M7 strut tower bar went on with no problems.
Old Apr 10, 2006 | 05:33 PM
petecrosby's Avatar
petecrosby
I think any of the strut tower stiffening bars will require you use the
un-modified strut mounting holes. Therefore you will have to use camber
plates which use the stock holes. I have RDR plates and and the M7 STB
and am quite happy with them.
Old Apr 15, 2006 | 04:28 PM
///ACS330Ci's Avatar
///ACS330Ci
Old Apr 16, 2006 | 07:45 AM
AZMCS's Avatar
AZMCS
Looks great Steve How long did it take you??
BTW, where you have them set in the picture is almost exactly where mine are at -1.0 camber with 1/8th toe settings. Oh, and I did finally move back to this setting yesterday from the autoX setting
Old Apr 16, 2006 | 06:25 PM
///ACS330Ci
Not long at all. I've had the struts on and off so many times I think I could do it with my eyes closed. It took me longer to get the car up on the lift! The thing is so low and the wheel base so short it makes it the hardest part!
Old Apr 16, 2006 | 09:42 PM
AZMCS's Avatar
AZMCS
Tell me about it! Gotta put mine up on wood blocks when I had it at the lowest point to get my jack under it
rtk90
Aug 29, 2019 09:08 AM
wesmc
R55 :: Clubman Talk (2008+)
Sep 28, 2015 12:07 PM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
Suspension Products
Sep 2, 2015 10:32 AM
