Door reflectors flying off!
Old Apr 8, 2006 | 10:29 PM
mciri's Avatar
mciri
Ok, I'm not sure if this is stinctly a "detailing" questiono, but here goes...
I have an 03 MCS and it has little round reflectors on the inside of the doors. I assume everyone has 'em, but I haven't seen any other MINI's.
Anyway... Mine keep coming off. I stick 'em back on, but they don't stay. I suppose I could glue 'em, but I was hoping for another tip.
Am I the only one with this problem?
Old Apr 9, 2006 | 12:31 AM
BFG9000's Avatar
BFG9000
If the tabs on the reflectors are cracked, they'll just continue to fall off until replaced with new ones. This is a common problem after door panels have been removed because the reflector has to be pried off to reach one of the panel screws. And the door panels have to be removed frequently to service the unreliable window motors.
The reflectors are available in red or white.
Old Apr 9, 2006 | 12:07 PM
89AKurt's Avatar
89AKurt
Mine just popped off! Hmmmm....
Old Apr 9, 2006 | 10:21 PM
mciri's Avatar
mciri
Bummer.... I guess glueing them on will make it kind of tough to get the door panels off, huh?
Old Apr 9, 2006 | 11:59 PM
BFG9000's Avatar
BFG9000
Depends; silicone is really soft but then you'd probably see it through the clear reflector. Have no idea what new ones cost since mine were replaced under warranty after the MINI tech broke them, but RealOEM.com lists the '02-'04 white ones as #51417067171.
Old Jul 6, 2006 | 08:28 AM
acitydweller's Avatar
acitydweller
use some 3m double sided tape
Old Jul 7, 2006 | 07:20 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Don't glue them directly to the door panel... You'll have a hard time removing them and could damage your door panel.
And you need to take them off if you have to remove the door panel...If you are still covered by the warranty, get them replaced. If not, buy some new ones, it's cheap and worth the extra $$$...
My MINI dealer, back in Montreal, broke one 3 years ago, and tried to hide it by using glue to stick it back... I complained and got them to buy a new one.
Peking Duck
Jan 19, 2021 03:17 AM
gar56
Nov 15, 2016 06:41 AM
jeri534
Nov 6, 2015 01:40 PM
dutchhome
Sep 30, 2015 07:17 AM
whowantstorace
Sep 27, 2015 06:16 PM
