D Stock brake lines/pads
Old Apr 3, 2006 | 07:09 AM
danielg's Avatar
danielg
brake lines/pads
13.6 BRAKES
A. The make and material of brake linings may be changed.
B. Substitution of clutch and brake hydraulic lines with solid metal
or braided metal is allowed on all cars manufactured before
model year 1992.
C. Alternate brake bleeder fittings such as “Speedbleeders” are
permitted. They may serve no other purpose.
Does the above mean you can use stainless steel brake lines?
Also, what's the best brake pad for autocross? I've heard the stock pads might be the best out there. What about the Mintex?
Old Apr 3, 2006 | 08:31 AM
Motoring's Avatar
Motoring
You can use stainless lines AS LONG AS YOUR CAR WAS MADE BEFORE 1992, was yours?
I really like the Ferodo 2500 pads, but they dust like crazy.
Old Apr 3, 2006 | 10:24 AM
danielg's Avatar
danielg
How did I miss that line!? Thanks.
Old Apr 15, 2006 | 05:59 PM
Mini Works's Avatar
Mini Works
The use both the Ferodo DS2500 and the Mintex 1144, (not the Red Box)
These 2 pads work really good.
Victor
Old Aug 27, 2006 | 06:21 AM
Johan's Avatar
Johan
EBC Stuff pads work really well!
About the Brake Lines, these from KaleCoAuto are by far the best out there -- Johan
Old Aug 27, 2006 | 03:03 PM
JustGo4It_'s Avatar
JustGo4It_
The stock pads work fine. I've never had them fade.
Old Aug 27, 2006 | 03:57 PM
mitchman's Avatar
mitchman
For autocross you don't change the pads because they fade, you change them for more/less braking force, better modulation, etc.....
Old Aug 27, 2006 | 09:06 PM
JustGo4It_'s Avatar
JustGo4It_
Thats kind of funny I aways thought if you needed more braking you pushed the peddle harder and if you wanted less you you were a little easier on the peddle.
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Sep 3, 2015 03:22 PM
