water pump
Old Mar 31, 2006 | 08:41 AM
timmiller's Avatar
timmiller
water pump
Hello all, I'm fixing a 2004 Mini Cooper (non-S). It took a hit to the front end. One thing damaged is the water pump pulley. Can I get just a pulley anywhere? I don't want to buy a new pump (especially since I can apparently only get one at BMW since the parts stores don't have anything yet).
Old Mar 31, 2006 | 08:45 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Judging by realoem diagrams, it appears that you can only get this part as a full assembly, however, it seems that even from the dealer, it's available as a reman part, so that could be a bit cheaper than an brand-new piece.
Old Mar 31, 2006 | 08:47 AM
Bigcoyote's Avatar
Bigcoyote
Hey there,
You might try a local import junk yard - or check on Mini2.com for breaker yards in the UK. But, if the hit was hard enough to break the pully it might have damaged the water pump also.
The motor is a Chrysler design - I don't know what else uses it ? but you might take the old pully to a NAPA or other large parts store and try and match it up to something??? I have had to do this with some of my large commercial trucks - once in a while you get lucky
Good luck
Old Apr 1, 2006 | 09:54 AM
k-huevo's Avatar
k-huevo
timmiller, I have a used MC water pump assembly (shipping charges only), P.M. contact info.
elverado
Jan 18, 2022 02:51 AM
patsum
26
May 29, 2021 06:29 PM
Fordgt4
Oct 10, 2015 10:42 AM
YoloSapien
Sep 25, 2015 07:12 AM
one73ronin
23
Sep 22, 2015 09:56 AM
