MOD recommendation
Old Mar 8, 2006 | 01:29 PM
krenzkes's Avatar
krenzkes
MOD recommendation
I'm going to the Dragon and thinking about a mod while I'm out there. Which should I go with pulley (15%) or air intake JCW type? If you could tell me why one over the other too please. I'm trying to increase MPG and get more zip too. What warranty impacts are there from the two?
Thanks,
Old Mar 8, 2006 | 01:32 PM
TWISTER's Avatar
TWISTER
Just do it!
Old Mar 8, 2006 | 01:46 PM
garretwp's Avatar
garretwp
By modding your car, you will reduce the mpg on your car, but not by much! If I were you, I would go with both if you can fork over the money. I would look into other intakes besides the JCW. You can save yourself some money and get another good alternative!
Garrett
Old Mar 8, 2006 | 01:53 PM
Motor On's Avatar
Motor On
Pulley install require removal of airbox so doing both could save you install costs and time, CAI will imporve MPG as long as that wonderful new sound doesn't motivate you to consantly mash the throttle. I love my ALTA CAI and I know many are happy with the Webb HDI. As far as warranty void on directly affected parts, the JCW kit puts on a redution pulley and many of us have racked up a ton of miles with pulley and intakes changed without issue so as long as the work is done right you should have no worries about reliablity making warranty irrelevent.
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
An air intake is a low cost mod you can do yourself with only a few tools and little time; no brain surgery kind of mod.
A pulley will take more money, take special tools and the knowledge to do it right.
I’d get the pulley done at the Dragon by some one who has the experience to do it right and do the air intake yourself.
Old Mar 8, 2006 | 02:05 PM
krenzkes's Avatar
krenzkes
This is good info of the pulley's which is best to go with Alta, Helix, M7? Also for intakes which is best alternative to JCW?
Sorry but I'm planning and want to get most bang for the buck whhile I'm there.
Thanks,
Old Mar 8, 2006 | 02:09 PM
Motor On's Avatar
Motor On
WhiteRoofRadio.com, past episodes, listen to the Randy Webb interviews he has done lots of testing and provide some very helpful and informative information. Its a balance between reliability, power and cost.
garretwp's Avatar
garretwp
All three pulley you have listed have been reliable and well made. It all depends on who you want to go with. I like the helix as it has six bolts to hold it in then the others with their 4 bolts. As for intakes, A good alternative to the JCW which is a closed box intake would be the HDI that has been announced from Webb Motor Sports. Alta and Pilo aslo have a good intake. I personally have the Pilo intake and have opened up the cowl area that the Alta does and Love it! You can not go wrong with any of them. I advise you to do a search on the forums and see what others have to say about them all.
Garrett
Old Mar 8, 2006 | 03:55 PM
Rawhyde's Avatar
Rawhyde
A word of advice on cold air intakes...
The JCW uses a paper element that costs $80-100. Keep that in mind.
There is now an aftermarket element that is washable foam for about the same price. Since I have a MCS/JCW, guess what my next mod will be?
Rawhyde
Old Mar 8, 2006 | 03:58 PM
garretwp's Avatar
garretwp
Exactly.... I can not believe that a paper filter would cost 80-100 dollars. I forgot to post that in my response! But for anyone interested in the JCW, keep that in mind!
Garrett
Old Mar 8, 2006 | 06:54 PM
krenzkes's Avatar
krenzkes
Between the Helix and the Webb Motors which is better? How loud is the Helix and Alta while normal driving or idle?
Old Mar 8, 2006 | 07:02 PM
BFG9000's Avatar
BFG9000
I got the JCW box because it was only $80 more to get it as a set with the JCW injectors. The injectors were used for the 19% and GIAC, of course. Gas mileage was unchanged, and those items work very well together.
That's the setup Helix prefers, but you are located right between Webb and Helix. Webb prefers the 15%.
Old Mar 9, 2006 | 10:16 PM
Barnabas's Avatar
Barnabas
EDIT: sorry! i posted wrong info lol. mods please delete
bADbOYbECK
41
Oct 16, 2015 12:39 PM
Burkee52
Electrical
Sep 18, 2015 11:12 AM
Moya45
Sep 11, 2015 02:21 PM
Tires, Wheels & Brakes
Sep 10, 2015 03:10 PM
Panik
Sep 9, 2015 08:36 AM
