Mini dealer only parts...
Old Mar 7, 2006 | 05:25 PM
Trickle X's Avatar
Trickle X
Ok, I am beat..and maybe a lil too tyred to search for the link, but does anyone have the link to the online parts lists for the mini? I need the oil filter housing cover to replace a leaking one. Mine cracked when installing the oil feed line for the turbo. Also, does anyone know of a dealer I can order the part from & have them ship it to me? After having to drive 2.5 hours to pick up an $8 exhaust gasket, I find my time spent wrenching instead of windshield time a better assest to the community!
Also on another note......who do I need to promise tons of useful data logging & research results from the Alta twurbo kit in order to obtain a copy of BimCom? Once I have this car up and running, I will be sharing all results with everyone here....or anywhere....heck.....I feel like i know this kit so well, that i can tell you what & where all the 212 parts go, torque specs, pitfalls, & settings you may or maynot want to use, routing of oil, coolant, & vacuum lines.....
so who needs help installing their kit??
Old Mar 7, 2006 | 05:43 PM
rhawth99's Avatar
rhawth99
Is this what you are looking for?
http://www.realoem.com/bmw/select.do
Morristown mini ships and Classic ships parts (Classic is a vendor on this site and Morristown is a sponser on Motoringfile).
Old Mar 7, 2006 | 05:49 PM
not-so-rednwhitecooper
Classic BMW ships. Ask for Jayson when ordering.
Old Mar 7, 2006 | 05:54 PM
Trickle X's Avatar
Trickle X
Yeah real oem is the site...thanks......I will be calling Classic 2morrow.....thanks...
Old Mar 7, 2006 | 06:08 PM
Trickle X's Avatar
Trickle X
Ok I see there is two units, one is the normal housing with filter & the other has a heat exchanger....anyone know if there is an aftermarket oil cooler that would be better than the stock unit/?
http://www.realoem.com/bmw/showparts...95&hg=11&fg=30
09R56
Nov 16, 2022 10:49 AM
Toolman
Jan 20, 2016 06:50 AM
minicoclub
Nov 11, 2015 07:25 AM
minicoclub
Aug 25, 2015 09:07 AM
