R50/53 15% pulley question
15% pulley question
I am going to the dealer tommorow to either order my new MCS or pick one off the lot. I will also be ordering the two grill pieces for the aero grill mod. I was wondering while I'm at it in a spending frenzy.... how hard is the 15% pulley install? Is it possible to do WITHOUT the tool? How long would it take your average backyard Fiat mechanic to do? Any DIY guides online? I appreciate any advice.
i have yet to do it myself, but i asked this same question the other day. the answer i got was you need the pulley removal tool due to space available to work with. they specifically said a regular pulley removal tool won't work, it'll just belt the inside lip. i think the biggest problem will be the lack of room in the engine bay. hope that helps
Helps a bit. I think I read somewhere you actually need to lift the engine? Is this correct? I dont mind puttin gthe time in.... hell spring is almost here! But I would love it if there were a DIY guide somewhere I could read.....
http://store.webbmotorsports.com/ind...b9d916f83d7b00
http://store.webbmotorsports.com/for...topic.php?t=17
You shouldn't be too intimidated if you're a backyard mechanic who can follow well-written instructions.
While you're at it you ought to consider a 17% pulley. I had a 15% on my first Mini and moved to the 17% with my new one. There is clearly more power and if you like the supercharger whine.....it's much more present. Also,
an ECU tuning upgrade would smooth the feel across the board. I used the
GIAC chip for tuning and it provides a wonderful new dimension.
alistaircookie
Oct 8, 2015 10:52 AM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
