Electrical Problem? Dome light stays ON if car not locked via remote (for days)
Old Feb 11, 2006 | 07:09 PM
Aviators's Avatar
Aviators
I realized that this is happening- if I forget to lock the car the dome light will not turn off.
I came out the other morning after driving another car for a few days to find the light still on in the car and the car unlocked (forgot to lock it).
Has anyone else encountered this?
Old Feb 13, 2006 | 08:32 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
Never had that. The most likely culprit is either that one of the doors (or boot) was not closed properly, or that you hit the unlock button on you remote. That lights up the dome light on my 03.
Old Feb 13, 2006 | 03:28 PM
Aviators's Avatar
Aviators
I guess I'll have to make sure everything's shut and then not alarm the car. How long should it take for the dome light to then go off?
Couple minutes?
Old Feb 13, 2006 | 04:27 PM
Agro's Avatar
Agro
Yeah...a couple of minutes should do it.
Old Feb 13, 2006 | 05:01 PM
ScottinBend's Avatar
ScottinBend
My interior lights go off after only about 30 sec. I wonder if this may be the cause of some of those dead batteries we keep hearing about?
Old Feb 13, 2006 | 06:09 PM
Tarzan's Avatar
Tarzan
Without arming the car, the interior lights stay on very briefly, then fade off. As soon as I arm, however, they instantly go off.
Now the interior lights do have a "permanent on/off" mode, and most likely you've activated that.
Just pressing the lights toggles them on or off.
If you press AND HOLD any of the dome lights or map lights for 5 seconds, you turn them to permanent on/off.
Old Feb 13, 2006 | 07:27 PM
Aviators's Avatar
Aviators
however would it be safe to assume that in 'permanent on/off' mode they would stay on even after locking the car w/ the remote?
Or would they exhibit the symptoms I mentioned?
Thanks, wasn't aware of this mode.
Old Feb 15, 2006 | 03:58 PM
bryan1970's Avatar
bryan1970
i'm pretty sure that even with the doors open the dome light will eventually go off. however it take more than a few minutes. it could be a faulty body control module or a shorted wire. have you had any electrical accesories intalled in the car?
lalroma
20
Apr 2, 2022 06:19 PM
Wohnson89
Jun 10, 2020 04:53 AM
oldkid6
Aug 11, 2015 08:13 PM
